Disco II Tool Kit
Old Aug 26, 2008 | 12:13 PM
unstable's Avatar
Default Disco II Tool Kit
Hey folks.
Went on a little trip to Maine this past weekend and the GEARBOX TEMP light popped on. I decided I wanted to check the transfer-case fluid and...stupid me, I didn't bring ANY tools whatsoever.
I ended up buying what I needed from NAPA and Walmart and it cost me a pretty penny...but at least now I have the 1/2 universal swivel deal to get at that fill-plug much easier.
I seen that places like roverparts selling a kit for $150, designed by ROVER ENGINEERS...it comes in a nice case with the Rover logo on it...but it just looks like some pliers and some other garbage that I can get for a few dollars somewhere else.
Point of this post...for those experienced, off-roaders especially...
CAN WE PUT TOGETHER A LIST OF MUST HAVE TOOLS FOR A DISCO I or II?
I'll kick this off:
1/2" ratchet - for removing fill plugs in x-case and differentials
1/2" universal-swivel for checking transfer case fluid
I know we also need that odd-ball deal to check transmission fluid.
Old Aug 26, 2008 | 12:43 PM
Disco2Guy's Avatar
Default RE: Disco II Tool Kit
I always have the following in my Tuffy box:
2x Bucket Boss Wrench Rolls with metric and SAE wrenches
Bucket Boss Tool Roll with screwdrivers (short and long, phillips and straight), hammer, scissors, pliers, needle nose, cresent wrench
Silicone Tape for radiator hoses/exhaust, electrical tape, duct tape, thread tape
Leatherman
Rubber mallot to bang out bent sliders (haven't needed it yet)
24" long 1/2" breaker bar with 1 1/16" socket (and extension because of steel wheels) for a lug wrench
Zip ties of various lengths
Steel wire
Various bolts and nuts
Saw
JB Weld
MagLite (2-AA in center console and 3-D in box)
Jumper cables
Folding shovel
Tire repair kit
Marine fan
Work gloves
Shop towels
Recovery strap
Air compressor (in side storage box)
I'm sure there are a few things I missed but that's most of it. When I go out I also have a small box of spares, and one for fluids.
Old Aug 26, 2008 | 12:52 PM
unstable's Avatar
nice list.
I'm definitely going to add some of that stuff to what I carry on the road.
At the very least, aside from the necessities to change flat tires, considering the reputation for Disco's to leak, it would be wise to have the stuff to check and add fluid...which for me is a little hand pump and the appropriate drivers to get the fill plugs out.
Old Aug 26, 2008 | 01:23 PM
Disco2Guy's Avatar
Yup, hand pump is in with the fluid storage box. I don't have the flexable 1/2" extension for the t-case fill plug so I had the fluid replaced when the brakes were bled and 3 amigos work done. That'll be one of my next tools to get.
Old Aug 26, 2008 | 01:42 PM
rmuller's Avatar
7th Gear
Here's a list I came upon a while back, I'd think it's mostly for a D1/D90/RRC, but some share;
[ul][*] 30mm socket for the nuts that hold the radius and trailing arms to the frame ears (also fits the nuts holding on the transfer case output flanges);[*] 15/16" socket and wrench for the for the fasteners that hold the radius and trailing arms to the axle;[*] 2 1/16" hub nut socket;[*] 12mm 12-point socket for the exhaust manifold bolts;[*] 13mm 12-point socket for the brake caliper bolts;[*] 9/16" socket and wrench for the driveshaft bolts;[*] 17mm wrench and 17mm deep and shallow sockets (there are M10 bolts everywhere on the Disco and your Hella 4k's are M10 as well)[*] 19mm wrench and sockets for your OME shocks;[*] 13mm wrench and sockets for your rubberized shock tower securing rings (and 13mm is another very common size)[*] 11/16" flare nut for your female-ended Paragon hoses;[*] 14mm flare nut for your male-ended Paragon hoses;[*] 9/16" 12-point socket for the bolts that hold the brake rotor onto the hub;[*] 17/16" impact socket for your wheel lug nuts;[*] Pozidriv 1,2,3 and 4 (I think the set screw on your parking brake is a Pozidriv 4);[*] 9/8" wrench for your crankcase drain plug (this also works on your Power Tank's regulator flare fitting);[*] 22mm wrench and socket for your panhard rod bolts;[*] a very long 14mm wrench for the 12-point bolts that hold the swivel ball housings to the front axle (a socket won't fit here);[*] 11mm socket for the swivel ball level and drain plugs;[*]1/2" square socket for your swivel ball fill plug [/ul]
Old Aug 26, 2008 | 03:05 PM
unstable's Avatar
really nice list. I think I'm going to work towards setting up a seperate tool box of just that stuff.
Old Aug 26, 2008 | 03:10 PM
rmuller's Avatar
7th Gear
Let's see.. what else d2 specific...
27mm & breaker bar for lug nuts ... better than lug wrench ..
32mm socket for hub stake nuts, and differential pinion nut
spark plug socket is always good to have too
Here is a list of what I carry, it's not up to date though, it was from a trip to canada last year.. I have to re-inventory everything before I head out to the national rally;
Pelican 1
5W30 (Qt)
White Lithium Grease
WD40
PB Blaster
Elec. Contact Cleaner
LR Jack
Blade fuses
OBD-2 Reader + Book
Multimeter
Dielectric
anti-seize
tire repair kit
5 D Batteries
wire crimper
black silicone
electrical connects
tire valve caps
Super 33 Elect. Tape
Duct Tape
loctite
small maglight
test light
tire inflator
tire gauge
teflon tape
cigar lighter
magnet
hand warmers (2)
air attachments
misc. allen keys
Pelican 2
70mm Pulley
Serpentine Belt
Brake Lines
Air Filter
250LB Zipties
Normal zipties
Spark Plugs
Ignition Wires
2 Lugnuts
crescents
front o2 sensors
rubber mallet
impact driver
hand saw
battery cable
misc wires
screwdrivers
pliers
stubby sockets
7qts 10w30
1 fram filter
fluid xfer kit
Recovery1
Wireless winch controller
Hard wire
Recovery2
D-Shackle
****** block
lift-mate
Recovery 3
30x3" strap
tree strap
Small Pelican
Passport
Camera
Insurance
Registration
Wallet
First Aid
Cold Pack
Thermometer
Imodium (4)
Booklet
Cleansing wipes (7)
Burn Cream
3" gauze pad (2)
2" Pad
Tylenol (2)
gloves
Gloves
scissors
Tape (2)
gauze
tweezers
Antibiotic cream (2)
Bandaids
sting relief
antiseptic tube
triangular bandage
conform bandage (2)
sterile pads (9)
Camping Bin
Pillow
air mattress
tent
rain gear
lantern
citronella candle
rain jacket
grill
Cargo Bin
Fire extinguisher
Bug Spray (x2)
Oasisplayer311
Aug 12, 2015 10:43 PM
DiscoBlanco
Nov 26, 2012 07:23 PM
simjack
Oct 12, 2008 10:24 AM
gda
Dec 26, 2006 06:01 PM
btobna
Jul 26, 2005 05:03 PM
