GAP Tool or Mongoose JLR Tool
Old Feb 12, 2015 | 03:12 AM
Oasisplayer311's Avatar
Default GAP Tool or Mongoose JLR Tool
Interested in one of these. I can get my hands on a Mongoose COPY for around $80, vs the GAP Tool for around $400. I want to be able to update my ECU and such, and wasn't sure if the GAP Tool was capable of this or not.
Thanks!
Eric
Old Feb 12, 2015 | 08:10 AM
drowssap's Avatar
I bought a copy of mongoose never got it loaded, requires a quite old lap top, i believe it has to be windows7 32bit or something like that.
Old Feb 12, 2015 | 08:56 AM
cmb6s's Avatar
Never used the Mongoose, but what ECUs are you wanting to update? There are about a million different ECUs on the LR3 and the IID tool will reflash a few of these. Off the top of my head, I know that you can update/reflash the following on the LR3:
1. The Body Control Module (to allow for things like 3 flash turn signals)
2. The Instrument Cluster ECU (to allow clock in gauge cluster)
3. The EAS ECU to accommodate the newer EAS compressor
4. You can update your Nav system to allow Nav on the move
5. The Bluetooth ECU to update to the newest Bluetooth software for the LR3 module
I think that's it as far as updating software...
Old Feb 12, 2015 | 10:48 AM
schwaggy's Avatar
Eric
Go here and enter your year for the ECU's the IID tool can flash.
IIDTool for Land Rover - GAP Diagnostic
Old Feb 12, 2015 | 11:41 AM
houm_wa's Avatar
Sooo....how do I enable the 3-flash turn signals? I have them on my 2014 Infiniti and I kinda like 'em.
Old Feb 12, 2015 | 12:32 PM
schwaggy's Avatar
It's on page 60 of the manual
Updating the BCM Body Control ECU adds the 3 turn flash feature. To work, it will also have to be enabled in the Car Configuration File (CCF).
Old Feb 12, 2015 | 01:38 PM
I have a Macbook Pro with a VM To run Windows XP 32bit, So shouldn't be a problem.
I wanted to be able to flash new Drivetrain Updates and TSB Updates to the ECU, along with the features of the GAP Tool.
Thanks Schwaggy! Do you guys think the GAP Tool is worth it? A lot of cash to dish out when a Copy of a Mongoose Tool is $80
Old Feb 12, 2015 | 01:45 PM
schwaggy's Avatar
I think so given all the fault reading and clearing it can do, the suspension, ecu's, etc... I probably paid too much via Lucky8 as you can get it from the UK for less, but I'm very happy with it. It's basically a modern day ODB scanner with 100 other uses.
Old Feb 12, 2015 | 02:40 PM
houm_wa's Avatar
IIDTool is VERY MUCH worth it. It's awesome for saved EAS settings and you want to run larger tires but only lift the LR3 at a trail head. ....and it has saved my a$$ at least once when my air shock wore out and I broke a ARB end link and the whole EAS went nuts. No problem, use the IIDTool to lift it back up, pull fuses and get the hell out of there.
I wheeled my way out of the South Loop of Tahuya (for those who know it) which is a pretty easy but slightly technical trail in western WA with NO EAS and a spent air shock. That's how bad a$$ the LR3 is, people!
Get the IIDTool, you'll be glad you did. Unless the Mongoose can really do everything the GAP product can do.
Old Aug 7, 2015 | 02:01 AM
moloha's Avatar
mangoose sdd clone, less than 50 bucks, is good at fault clearing, displaying live data, and specially datalogging features.
What is very helpful is to go into the datalogger (under header maintenance or recommendation, can't remember) and go into the list of parameters that can be recorded. Mongoose has to be attached to computer to work. This also works without connection to the car. I was amazed how much info on the different parts of the car is in there. Loading it on Win XP, no risks!
