Disco II Transmission Temp Sensor
Old Mar 25, 2011 | 11:41 AM
Chaosdoc's Avatar
6th Gear
Sorry guys still raining here and i don't have an interior garage. I should get to it this wkd and I'll let everyone know my results, thanks again.
Old Mar 28, 2011 | 02:46 PM
Chaosdoc's Avatar
6th Gear
Well as fortune would have it, it is the sensor on the front tranny radiator. I disconnected the coupler at the top of the radiator on the passenger side and the light did not come on in the key position 2 on a non-running engine. reattached it and it came on. I also checked the easy one under the truck and it did not affect the light's illumination.
So how to get to the sensor on the tranny radiator. I looked at the service manual on line but it has no instructions on how to get to it. (not the rave manual) the LANDROVERRESOURCE.COM one.
Suggestions?
Old Mar 28, 2011 | 08:46 PM
SDinDS's Avatar
Raise and remove the front right tire. Remove the plastic wheel well cover. Life the flap that covers the side of the radiator and you will see the temp sensor at the bottom of the trans cooler. Unplug the sensor wire (by the top of the radiator) and remove the bolt that holds the bracket. Use a 7/8" wrench to remove the sensor. You will lose a little bit of fluid. Put the new sensor in and top off your trans fluid. The whole process should take you about a half hour.
Eric
Old Apr 20, 2020 | 06:50 PM
HFALONZO's Avatar
8th Gear
Originally Posted by Chaosdoc
Just had a lot of rain and drove thru 1ft-2ft of water yesterday, now before engine even turns over, (key position 2) the trans temp light comes on... on a cold cold engine?
So where is the sensor(s) located to check connection and replace if need be?
Thanks all...
Hey guys! I got the same problem with my disco 2 2003, but after disconnect both sensors, the light on the dash still goes on!! Any help would be awesome! Tranny oil good, level good so Im confused...
Many thanks
Old Apr 20, 2020 | 06:59 PM
Extinct's Avatar
Sounds like you have a shorted wire somewhere.
Old Apr 20, 2020 | 08:50 PM
HFALONZO's Avatar
8th Gear
It seems you are right, does anybody has an electrical diagram ? So I can follow the route of the wires.
Thanks fir your answer!!
2Discos
Sep 9, 2013 04:23 PM
collin Barrows
Aug 8, 2011 09:33 PM
spanky melton
Mar 30, 2011 10:57 PM
rrbc
Nov 13, 2009 04:59 PM
