Disco Mike Rocks
Old Mar 31, 2009 | 03:10 PM
okdiscoguy's Avatar
Originally Posted by david1289
How do you flush the coolant and power steering to do this 60k mile service?
Also, do you need to flush the transmission?
I am wanting to do this at 90k for my 2003 Disco. Or should I let the dealership do the 90k service?
Take off the lower radiator hos and drain. Fill with water and flush. I did it a couple of times until clear water came out. Re-fill with the proper mixture of Dexcool, remembering that you will not get all of the water out of the block when you flush unless you remove the block drains. Then make sure to bleed the system proprerly.
For the p/s, easiest way is to take a turkey baster and suck all of the fluid out of the tank. refill, drive around and repeat.
Fivespddisco
Nov 5, 2009 08:56 PM
phil29
ROAMING WITH FRIENDS
Oct 26, 2009 04:09 PM
sn1987
Tires
Oct 26, 2009 09:25 AM
Fivespddisco
Aug 29, 2009 08:13 PM
rover2003
Dec 9, 2007 09:06 AM
