Disco No Start continued
Old Jul 4, 2008 | 06:33 PM
bitter356's Avatar
8th Gear
Default Disco No Start continued
Has anyone heard of this or is it fiction. On the RAVE cd under engine managemaent "When a new crankshaft position sensor is fitted or the flywheel removed,the adaptive values will have to be reset using TestBook." Any feedback on this??? Is there anyway to do this without TestBook???
Old Jul 5, 2008 | 09:37 AM
roverguy7's Avatar
Default RE: Disco No Start continued
not entirely true, yes they should be reset, but they will relearn themselves over time and be right... the point of the adaption is so the ecm can learn any irregualities in the flywheelexciter ring, what it uses to know when to spark each cyl, youll never be off enough to cause a no start or anything just by changing out a sensor. as to doing it with out a t4, ive never seen a way, but who knows
Old Jul 5, 2008 | 10:03 AM
jkid's Avatar
I replaced mine without any problems that I'm aware of, so yeahI guess you don'tHAVE to.
Old Jul 5, 2008 | 09:18 PM
bitter356's Avatar
8th Gear
Thanks for your imput. I removed the new sensor and observed the rotating ring to result of the ring undulating back and forth 1/16". Is that enough of a variance to cause a no start? I also checked continuity for all connections from the sensor to the ECM and checked out good.
Old Jul 9, 2008 | 07:08 PM
roverguy7's Avatar
probably not... when it doesnt start, does the check engine light turn off while cranking??
Old Jul 14, 2008 | 09:20 PM
bitter356's Avatar
8th Gear
Yes, while cranking, the CEL light goes out
Old Jul 17, 2008 | 09:16 PM
roverguy7's Avatar
that means youre gettinga good signal from the crank sensor... you have a seperate problem, could be fuel pressure, could be blown fuse number 2 under your hood, could be alot of things, check those first
ShadowMerchantBC
Jan 28, 2013 11:30 AM
Camdisco24
Aug 8, 2008 08:36 AM
Camdisco24
May 15, 2008 07:41 AM
fitch11
Feb 18, 2008 05:56 PM
audiurq
Feb 15, 2007 03:42 PM
