Disco passenger window
I had the passenger window down on my Disco and when I tried to raise it it doesn't move. The motor is making a rattling noise, so I removed the door panel and the glass will not move up in the slightest if I try to push it up. I looked inside with a flashlight and it looks like the operator arm has traveled too far and is jammed by a small metal punch out on the mechanism, do I just drop the motor to move the window or is this another problem? I would like to get the window up if nothing else for now.
the motor assy is bolted to the window regulator assy. you will need to remove the glass from the regulator which will allow you to unbolt the regulator/motor assy from the door.
drowssap
04-05-2011 12:17 PM
Spencerfitch
05-03-2010 02:56 PM
