Disco radiator
my rad is leaking on the drivers side where that screw that hods the bracket goes into rad
I did just buy a 99 disco for parts but not sure if I want to put in that old rad
my question is are the rads from rock auto any good and durable ?? My local suppliers want $760 plus tax here in Canada
![What He Said ^^^](https://landroverforums.com/forum/images/smilies/pointup2.png)
This.
This is the rad i bought for MagPie and its been working just fine. Even if it turns out to be sh-t, i'll just buy another because.. its $60.
https://www.ebay.com/itm/35192142814...&s=ci&mail=sys
Sixpack577 (07-26-2018)
Yep all the cheapie radiators I’ve used and installed have worked out great. Small tip on the re-install. Take the screws that secure the lower shroud to the radiator (where you usually get leaks) and cut off like 1/4 of an inch off of them! They will still hold the lower shroud, but they shouldn’t go to far & put a crack into the plastic radiator tank.
thanks for the tip
