Disco stalling when idle
Old Jun 16, 2005 | 04:33 PM
slamwhit's Avatar
Default Disco stalling when idle
Almost every time I start up my 95 Disco, the idle goes way down and I have to rev the engine to get it up so it doesn' stall. When I shift into gear, the idle goes down again and I have to do the same thing. It sputters when I press on the gas when starting it up. To me it seems to be something with the fuel line but what do I know? I'm just a dumb blonde.
The problem only seems to occur when starting up the car- not while driving.
Old Jun 16, 2005 | 05:21 PM
mikemeyer0's Avatar
Default RE: Disco stalling when idle
let's say you pull up to a stop light does it then do it. How often, all the time, once in a while? Could be fuel filter, when was last time it was changed?
Old Jun 16, 2005 | 05:49 PM
slamwhit's Avatar
Yeah, it sometimes does it at a full stop now that I think about it. It's not all the time though.
Fuel filter? Good question! I'll check that.
(Although with my luck it won't be that simple.[8D])
Old Jun 16, 2005 | 05:59 PM
mikemeyer0's Avatar
ORIGINAL: slamwhit
they are cheap enough to just change out and pretty easy.
Old Jun 17, 2005 | 05:11 PM
anonimaus's Avatar
Before you try to take the filter off, I would give the connections a couple of shots of PB Blaster and wait a couple days and do it again. It will make it easier to separate the fittings.
If this doesn't work, I would look towards the stepper motor - could be carboned up. I would also look at the vacuum tubing for dry rot.
misterme
Jul 2, 2014 09:06 PM
misterme
Mar 9, 2014 07:59 PM
demonlarry
Jun 28, 2013 03:10 PM
Rover5150
Nov 28, 2007 09:57 AM
Rover5150
Nov 26, 2007 06:09 PM
