Disco was towed with dolly 200 miles
Old Sep 25, 2018 | 08:00 PM
shanechevelle's Avatar
Put your location in control panel so we know where you are.
Old Feb 22, 2019 | 09:03 PM
gsxranger's Avatar
Well, here's the damage report. The motor was knackered with a spun rod on the crankshaft, I took the heads to the machine shop and had them rebuilt, and got a junkyard lower end. After an epic garage battle and thanks to Atlantic British for the videos - seriously I couldn't have done it without them - all back together and runs great.
Now the transmission: I seriously thought about just pulling it with the motor out, but hoped to get lucky. Unlucky! I drained the fluid, it looked and smelled fine. Dropped the pan and swapped the filter, not an unusual amount of gunk in the bottom. All back together and the trans "whines" like a bad power steering pump from about 900 rpm to about 1100 rpms. Not super loud, just enough to be slightly annoying. It shifts smoothly and feels great, and makes no noise above or below that range.
Any bets on how long it will go? Emminent failure replace now or should I just let it run?
It is about the nicest D2 I've ever seen.
Old Feb 22, 2019 | 09:10 PM
You sure the torque converter seated properly?
Old Feb 22, 2019 | 09:33 PM
gsxranger's Avatar
I believe so, the noise is there whenever the vehicle is running, park neutral or otherwise. I think that rules out the converter?
Old Feb 22, 2019 | 09:35 PM
gsxranger's Avatar
Also, I did not remove the torque converter, just unbolted it from the flex plate.
Timw479
Apr 12, 2018 10:20 AM
WickedRED
Mar 15, 2011 12:19 AM
btbaus
Feb 7, 2010 09:48 PM
jesse682000
Nov 11, 2007 10:54 AM
