Disco trans prob
Old Mar 25, 2010 | 07:41 PM
ROVERTECH15's Avatar
Default Disco trans prob
hi guys new to the forum,one of my rovers just starting doing somthing very odd.seems when the truck gets warm the truck will shift fine but when u shut the truck off and then turn it back on when u shift into reverse it takes about 6 seconds before it engages.i work on rovers for a living but amnot a trans tech by anymeans i have my own shop in nj. it also does this in drive under the same scenario.the truck is a 2001 disco2 with 180000 miles on it runs great i would just like to avoid buying a new trans for it.thanx guys
Old Mar 25, 2010 | 08:14 PM
Classic signs of a clogged trans filter.
Old Mar 25, 2010 | 08:22 PM
it has been recently changed spike
Old Mar 25, 2010 | 08:36 PM
greg409's Avatar
What if the trans fluid had not been changed (maybe ever?) in 180k?
How did it look inside?
With new fluid & filter, I could see the crap circulating & wreaking havoc with the valving.
If it's shifting ok, I'd drive it as much as poss.
I'd also change the fluid again. (drain the pan)
It might start behaving & you're not out much by trying.
luck,greg
Old Mar 25, 2010 | 08:39 PM
thanx greg i have changed the fluid every 50k and it does shift quite well for a trans with that kind of milage it seems like the fluid is too hot in my opinion only does it when it is warm out soooooo wierd.
Old Mar 26, 2010 | 05:11 AM
First, the fluid should be changed, by the books, every 30,000 miles.
You should have a tranny fault code, something in the 700 to 801 range, get a scanner on it and see what shows up.
Old Mar 26, 2010 | 09:10 AM
thanxs disco mike i was hopin u could help me with this the truck is not putting out any codes whatsoever i have checked twice with my x41 scanner this is why it is so boggling to me i can usualy handle just about anything with discos but this one is not giving me any help other then the trans might be on the way out because of the milage
Old Mar 26, 2010 | 09:19 AM
Then you may need to find a friend in the tranny business that can either plug into it or hook in and verify pressures.
Old Mar 26, 2010 | 10:57 AM
Smile
ok thanx mike i thought mabye i could mabye do a quick fix thought it might be somthing dumb that i missed or overlooked but i guess not i am going to try some lucas trans treatment and if that does not work my buddies dad owns a junkyard and said he had one with 60k for $500 guess ill just play it by ear and see what happens it does not do it consistent enough for me to slap a trans in it right away like i said only does it in warm weather when the truck warms up
Old Mar 26, 2010 | 04:06 PM
Is the trans temp sensor any good?
Maybe its overheating and the light is not being set off?
