disco want make a sound
replaced the fuel pump because it went bad,unhooked the bat cable to install the fuel pump, once i was done,hooked the cable back up, tryed to crank up the truck and it would not turn over. tryed the unlock 3times thing did not help. but right b4 i unhooked the bat. it would turn over but not crank
on
Pump probably wasn't bad, that is the problem with replacing parts like you know what your doing without asking for help first.
If you spray carb cleaner into the t/body, reinstall the hose and try to start the engine, will it start?? Does it have spark, did you check the fuse and has the fuel relay been replaced?????
let me start from the begining.truck started cut out a 70 mph some times bout two weeks a go, i thought it was bad gas. so sat my wife was drivn and she said it flt like was running out of gas so she filled up,started comming home,pulled a hill and the car shut off.so i walked to the car started the car, and i can hear the pump sounded real weak,droved the car about 100 yards and it sputterd home like the pump was going out.cut it off, tryed to start it and it would not start. installed a pump and now still wont start im go check and make sure its getn power to the back, and let yall know.
changed it bout a month ago, got one from oreillys,i think it might be a bad pump,gettn 12.8? at volts at the pump on purp/wht and black wires with the key in on position, but the pump still not comming on
