disco want make a sound
Old Jun 23, 2009 | 09:43 PM
Have you replaced the fuel pump relay?
You are not the only one who has had this problem, the only bad part is nobody ever posted the actual fix.
They replaced the fuel pump, the relay and still no fuel pump. And no post of the fix.
Replace the fuel pump relay and then see if it works.
Old Jun 23, 2009 | 10:56 PM
bowtiecb's Avatar
ill try that, i called the local dealer and he said 2 or 3 days to get one in, but i do have one ? if the relay is bad wouldnt that cut the circuit,and the volt would read 0,cause im getn 12+ volts with the key in on position.also thanx so far
Old Jun 24, 2009 | 08:48 PM
bowtiecb's Avatar
fixed, cleaned the connections at pump and she fired right up
Jared9220
Jun 8, 2014 11:49 PM
Francisco
Mar 2, 2011 07:26 AM
range_time
Sep 24, 2010 10:01 AM
03discoman
May 8, 2010 07:04 PM
