Disco won't blink
Old 12-24-2009 | 10:39 AM
BIG's Avatar
BIG
Default Disco won't blink
At temps below 28 degrees the blinkers will not work with out movng the switch 3 or 4 times. Temps above that they work fine. Any ideas on what might cause this or how it can be fixed? Any ideas would be appreciated.
Old 12-24-2009 | 10:40 AM
BIG's Avatar
BIG
Forgot to mention this is a 2000 Disco SD.
Old 12-24-2009 | 05:32 PM
JavaRacer's Avatar
Dude, I have the same issue. Windshield wipers also. Seems that if I leave the switch on for a bit, it eventually starts working. I'm definitely interested if anyone has ideas!
Old 12-24-2009 | 05:46 PM
tweakrover's Avatar
x3 with the turn signals
Old 12-24-2009 | 05:50 PM
Camdisco24's Avatar
You need to change your blinker fluid, here's how:
http://www.ehow.com/how_4716293_chan...ker-fluid.html
And here's where you can get some:
http://kalecoauto.com/index.php?main...&products_id=6
Sorry thats all i've got.
Old 12-24-2009 | 06:11 PM
tweakrover's Avatar
found some at autozone, its not the synthetic, but it was an emergency. topped it off and the are back to blinking full speed. thanks
Old 12-24-2009 | 06:19 PM
DavidG's Avatar
Mine does the same thing but works fine if I slightly pull the stalk towards me.
Old 12-24-2009 | 06:36 PM
You guys all need new switches.
When they get cold the contacts shrink and dont contact each other thus no worky.
If your cabin is nice and toasty they will work.
When you have the heater on turn it to vest (or dash) and turn the vents towards the switches, once they heat up...good to go.
Old 12-24-2009 | 08:27 PM
tweakrover's Avatar
I thought it might be the flasher unit, mine come on solid til it warms up. Would that still be the stalk?
Old 12-24-2009 | 09:29 PM
That one I do not know.
