Disco won't blink
Old Dec 24, 2009 | 09:39 AM
BIG's Avatar
BIG
Default Disco won't blink
At temps below 28 degrees the blinkers will not work with out movng the switch 3 or 4 times. Temps above that they work fine. Any ideas on what might cause this or how it can be fixed? Any ideas would be appreciated.
Old Dec 24, 2009 | 09:40 AM
BIG's Avatar
BIG
Forgot to mention this is a 2000 Disco SD.
Old Dec 24, 2009 | 04:32 PM
JavaRacer's Avatar
Dude, I have the same issue. Windshield wipers also. Seems that if I leave the switch on for a bit, it eventually starts working. I'm definitely interested if anyone has ideas!
Old Dec 24, 2009 | 04:46 PM
tweakrover's Avatar
x3 with the turn signals
Old Dec 24, 2009 | 04:50 PM
Camdisco24's Avatar
You need to change your blinker fluid, here's how:
http://www.ehow.com/how_4716293_chan...ker-fluid.html
And here's where you can get some:
http://kalecoauto.com/index.php?main...&products_id=6
Sorry thats all i've got.
Old Dec 24, 2009 | 05:11 PM
tweakrover's Avatar
found some at autozone, its not the synthetic, but it was an emergency. topped it off and the are back to blinking full speed. thanks
Old Dec 24, 2009 | 05:19 PM
DavidG's Avatar
Mine does the same thing but works fine if I slightly pull the stalk towards me.
Old Dec 24, 2009 | 05:36 PM
You guys all need new switches.
When they get cold the contacts shrink and dont contact each other thus no worky.
If your cabin is nice and toasty they will work.
When you have the heater on turn it to vest (or dash) and turn the vents towards the switches, once they heat up...good to go.
Old Dec 24, 2009 | 07:27 PM
tweakrover's Avatar
I thought it might be the flasher unit, mine come on solid til it warms up. Would that still be the stalk?
Old Dec 24, 2009 | 08:29 PM
That one I do not know.
