Disco Wont Start
Old Feb 28, 2015 | 01:41 PM
Huuflungpoo's Avatar
Default Disco Wont Start
Finally got the disco pulled out of the snow....Put a new battery in and go to crank and see what happens...and all i get is cranking nothing else it tried to fire once then died instantly...anyone got some ideas....no lights are flashing.
Old Feb 28, 2015 | 06:26 PM
Alex_M's Avatar
Any other symptoms? Any problems prior to replacing the battery? Why we're you stuck in the snow?
Old Feb 28, 2015 | 07:53 PM
dr. mordo's Avatar
Is the tachometer moving when you crank it? If it isn't moving, you have a bad crank position sensor.
If it is moving, I'd try swapping the fuel pump relay with the washer relay next to it. If it still won't crank, you need to go back to basics and check for spark and fuel.
Old Feb 28, 2015 | 08:37 PM
I bought it while it was in the snowbank....i only paid $250 for it....ill check to see if the tach moves when i go out in the morning.
I already did the relay swap anyways...didnt really think about watching the tach tho.
Old Mar 1, 2015 | 12:40 PM
Went out this morning to try it and the Tach doesnt move so i will order a CPS and see what happens then
Old Mar 2, 2015 | 06:50 AM
drowssap's Avatar
if it is a DII i "believe" the tach does not work until the truck has fired, if you want to check the CPS you need an obdII scanner
Old Mar 2, 2015 | 07:23 PM
dr. mordo's Avatar
It looks like drowssap is right! You have to use a obd reader to check the rpm, the gauge will show nothing til it cranks.
Sorry if I sent you in the wrong direction.
Old Mar 3, 2015 | 07:05 AM
Well this should be fun...will it throw a code or do i need one of the higher end obd2's to check it while im cranking it?
Old Mar 3, 2015 | 07:53 AM
drowssap's Avatar
check for live information on your obdII and see if the rpm changes when you crank it
Old Mar 3, 2015 | 05:25 PM
dr. mordo's Avatar
I highly recommend buying a cheapo bluetooth obd2 reader. It talks to your smartphone. Buy the app called "torque" and you are in business.
