Disco2 Window Regulators
I had to replace the DSF regulator last week; I went with this item: https://rover.ebay.com/rover/0/0/0?m...2F263878409461
I was not disappointed!
Fast shipping
Quality product
Easy Install
Three things you need to do when transferring hardware from old regulator:
Use some lithium, silicate, or gel lubricant to grease the gear head before installing the motor.
Do the same for the interior of the track rails.
Make sure you have the regulator rolled out into an X formation with one tracking wheel at each end of the regulator track; and then unsure that you attach the center wheel block to the rail (the square white plastic device that sits on top of the center of the rail.) that block prevents the wheels from rolling too far down onto the regulator track and being driven out of the ends of the track.
This entire installation process took me about 30 minutes (if that).
Doc
Fast shipping
Quality product
Easy Install
Doc
Savannah Buzz
04-01-2012 01:26 PM
