Disconnecting the battery
Old Jan 26, 2008 | 07:50 PM
jkid's Avatar
Default Disconnecting the battery
Does disconnecting the battery in D2's cause any problems? I've read about radio codes and such in D1's and Rover's, but not D2's.. Do D2's need radio codes and should I try to get mine for the future. Thnks.
Old Jan 26, 2008 | 09:01 PM
Default RE: Disconnecting the battery
Yes, you need the radio code.
Old Jan 27, 2008 | 07:59 AM
Why are you wanting to disconnect the battery?
D2's aren't as bad as D1's were about radio codes, but you better have it just in case, also you will have to reset your a/c controls to read the correct temp.
Old Jan 27, 2008 | 08:41 AM
jkid's Avatar
ORIGINAL: Disco Mike
Just in case mostly.The battery doesn't seem to hold a very good charge (12.3 volts)so I was going to bring it inside (it's freezing out) and give it a good charge. I'll probably just wait a few days though since it should be a bit warmer out and leave it hooked up to charge. I haven't had a chance to check the charging system on the truck at all yet. Anyways, I'm guessing I'll need to switch it with a new one before too long since it's probably the original battery.
So, I found the dealer that used to service the truck before I bought it, would they have the code?
Old Jan 27, 2008 | 08:45 AM
jkid's Avatar
Never mind, I found the security and radio code in my nice LR owners manual / attache case. Imagine that.
Old Jan 27, 2008 | 09:06 AM
Just go by your auto parts store, save some effort.
Old Jan 28, 2008 | 09:53 AM
DV57's Avatar
When I swapped the factory battery w/a new Optima battery, the only "hitch" was switching my A/C from Celcius to F.
That was very easy.
My radio was fine.
stevey88
Sep 11, 2012 12:10 PM
liPPy
Dec 30, 2010 02:49 PM
zracin
Sep 12, 2008 07:41 PM
apcollin
Sep 9, 2008 09:09 AM
texaninmass
Feb 5, 2007 11:54 AM
