Discount Tire says LR Wheels are "odd"
Old Dec 10, 2014 | 05:12 PM
  #21
OffroadFrance's Avatar
Originally Posted by Syzygy
Whenever I'm asked if I want to buy an extended warranty, I always ask the salesperson if the product is so bad that it NEEDS an extended warranty. Then I hem and haw as I rethink the original purchase.
I usually go ahead and buy the product, but the look of panic on the salesperson's face as they realize that pushing the extended warranty is about to cost themthe sale is priceless.
Excellent.
I bought a new Samsung TV on offer in Leclerc a few weeks ago and the girlie asked me if I wanted to buy extended warranty (as they always do) - I said exactly the same 'does it need it then' answer was "no" so then I won't have it was my reply
Old Dec 10, 2014 | 09:56 PM
  #22
Team140's Avatar
5th Gear
I can add my own personal experience with this. Granted, they weren't Yokos, but I had a set of Treadwrights put on a D1 back in 2007 at a Wal-Mart service center. During the install, the shop manager came and got me and asked what was so special about the tires. I told him they were standard retreads and there's nothing special about them. He headed back to the garage bays.
A few minutes later it sounded like a shotgun went off in the building. I just stepped into the work area when it happened and my ears were ringing. That was the sound of the bead seating at well over 100PSI. All four tires did that. It scared the new techs, but the guy mounting them said he's seen it happen on other Land Rovers, but didn't know if it was the tires or the rims that caused it.
My guess is LR wheels are on the large side of the tolerance window for the rim diameter and some tire manufacturers are on the small side of the tolerance for the rim diameters.
Old Dec 10, 2014 | 09:59 PM
  #23
jafir's Avatar
Could be the bead retaining ridge on the wheel. I think this caused damage to my old tires when they were REMOVED to install the Yokohama tires. I think my old tires were bridgestones.
Old Dec 10, 2014 | 10:22 PM
  #24
lordmorpheus's Avatar
I am going with wheel design. I have never had such difficulty removing a tire from a wheel as I have while dismounting on a professional tire machine. Getting them to bead was a bit of a chore also. I have a sneaking suspicion LR designed these wheels as to let tires be run at a lower pressure without as great a risk of unseating the bead. The crappy summer sport truck tires that were on it when I bought my Disco were torn to shreds when a "tire tech" unmounted them. I decided to do my own next time (it's nice having friends who own shops). Even with bead lube, the BFGs fought me coming off, and the Coopers fought me going on.
Old Dec 11, 2014 | 11:03 AM
  #25
If you look at genuine LR wheels and measure them you'll note they are a tad larger diameter with a higher ridge which is effectively to bead lock the tires without any special locker. Often aftermarket wheels allow the tires to creep under extreme torques and sometimes damage the tire or the rim.
Spot the difference Résultats Google Recherche d'images correspondant ŕ http://i170.photobucket.com/albums/u247/GromitThedog/DSC_3579.jpg
Old Dec 11, 2014 | 11:34 AM
  #26
locknload7's Avatar
That's quite a story about the tire unseating and going off like a shot gun. 100 psi seems excessive to me at least based on any of the vehicles I've owned. I read a lot of horror stories about different tire shops doing this stuff wrong and causing real damage. I'm thinking the installers are more prone to human error than a tire and rim is likely to fail on it's own. Based on other's experience with the Yokohama tires, I'm guessing the Discount Tire memo is an indicator of their inconsistent abilities across all their stores and not an indication of the tire's quality.
arnottdoug
Member Group And Special Buys
Jun 19, 2014 07:10 PM
DROVER1984
Nov 7, 2012 09:05 AM
Airwolf1
Jun 11, 2010 09:45 AM
_Chris_
Feb 9, 2010 11:19 PM
spdfreek007
Feb 7, 2006 03:04 PM
