Discovery 1997
Old Jan 28, 2010 | 06:46 PM
deseraligears's Avatar
Default Discovery 1997
lokking at a discovery with 125000 mi the guy has had it for awhile says it is now running hot radiator sun roof and windows either off track or not working when I look at it last July the hood had faded and the front above the
windshield .
Last summer he wanted 2500now wants 2000 beside what I said it is in good shape, so buyer beware thoughts? Thinking off offering 1200
in good condition what it be worth? 3500? Thanks as always oh I asked if he was using premium he said no !
Old Feb 4, 2010 | 11:35 AM
bdoyle1742's Avatar
well premium thing not a crazy big issue(although you wouldnt ever catch me putting anything below 93 in mine). With that said, I owned a 97 a while back with 160k. It had hardly any compression left when I was done with it, and I took great care of it, oil changed every 3000, plugs changed reg. It is very important to know what you are buying, I had no clue it would be that bad just because of the mileage, but it was. As for the asking price not bad, even if you gotta pay 2000, but if you get your low ball price in, more power to ya.
Old Feb 4, 2010 | 11:41 AM
okdiscoguy's Avatar
If it is running hot, I would say the radiator is getting clogged. Most common reason for this. You will probably be looking at the water pump, hoses, belt, tensioner as well if you don't want to worry about it anymore. Look for the 60K service on here and plan on doing that along with plugs and wires (8MM only). $3500 is average for a good one. The fading paint is common, and can be re-sprayed for under $500. I did mine myself in the garage..
I would say premium is a big issue. If not used, it will carbon up your heads and cause valve failure. Not to mention it will kill your performance and MPG. If the truck is decent, $1200 would be a good price. $2K is good if you can work on it yourself..
Old Feb 8, 2010 | 09:14 AM
Default 1997
Thanks have not heard back so he may have sold it.
adamhannah
Aug 1, 2011 01:41 PM
tymecard
Sep 27, 2005 10:41 PM
charvey
Jun 25, 2005 03:11 PM
vicki
May 12, 2005 02:31 PM
Potomac Paddler
Oct 17, 2004 04:42 PM
