Discovery 2 - 2004 - No Start
Good Afternoon,
Upon reinstalling my fuel tank and attempting to start engine, it fired and ran for a few seconds before sputtering and stalling. Not too surprising since the fuel line was disconnected. Another similar but shorter duration startup followed. What was surprising is that it now refuses to fire at all. I have been troubleshooting for a while now and have gathered the following information:
Fuel pump seems to be activating as there is pressure in the line if I disconnect it and there is voltage at the plug when the engine is cranking.
Spark plugs are sparking.
OBD2 indicates ECU is reading ~200 RPM when cranking.
Spark plug is dry when it is removed.
So it would seem that the injectors are not being allowed to activate. I would be interested in knowing if anyone has heard of an issue like this before. Any help would be appreciated!
-Michael
-Michael
The Deputy (10-03-2021)
Hi guys, thanks for the responses.
I forgot to mention that did try to reset the inertia switch, which did not change anything. Additionally, wouldn't the hazard lights be activated if the inertia switch was activated?
Regarding the CPS; is it correct to assume that since I can read the engine RPM from the ECU via OBD2, the CPS is functioning properly?
I should also mention that after cranking the engine for a couple seconds, three beeps are heard, just like when the center differential is locked. And four lights flash on the instrument panel - I believe it's the Hill Descent Control, Traction Control, and two other amber lights.
I also read somewhere that the Cam Position Sensor could cause this symptom and that disconnecting it may free up the injectors. This had no effect.
- Michael
- Michael
Richard Gallant (10-03-2021)
I see, so we can probably rule out the Cam sensor with reasonable confidence.
One thing I did try since last night was that I unplugged the inertia switch, this immediately caused the 4-way hazards to activate. What was puzzling to me was that I could not deactivate the hazards by pressing the top of the IS. Could this indicate a failure in this switch? Also I remembered that I got a code for P1590 - Rough road sensor fault a few weeks ago, not having returned since I recorded it and cleared it; could this be related to the inertia switch?
Thank you
Thank you
