Discovery 2.5 TD ES 300 series
Old Apr 26, 2005 | 06:22 PM
livewire's Avatar
8th Gear
Default Discovery 2.5 TD ES 300 series
Hi
Just got my Land Rover, it has full Land Rover service historye tc. After four days of running it, I was travelling 60mph and I could hear a noise clicking , a continous clicking noise. The noise did not stop, I turned the engine of for 20mins and started her up, again a clicking noise and a small amount of fluid laid on the floor. I cleaned up the fluid and started the engine again the noise was not as continous or loud and no fluid leaked.
The temperture indicator did not go up, hope someone can help. Pleaseeeeeeeeee.
thank you for any ideas you might have
6 months ago the history states all belts were replaced.
Damon
Old Apr 26, 2005 | 06:41 PM
mikemeyer0's Avatar
Default RE: Discovery 2.5 TD ES 300 series
what kind of fluid and where did it look like it came from?
Old Apr 28, 2005 | 05:30 PM
livewire's Avatar
8th Gear
Hi
Went away on bussiness for the day. The fluid seemed to be water and anti-freeze. I have also looked through the service history, all belts were changed approx 4 months ago and has done 1000miles since the belt change. When I start the engine a loud clicking noise seem to becoming from the front of the engine. After reading through the forum I'm beginingng to lean towards it being the water pump bearing - because of the tension from the new belts. I'm by no means a expert or mechanic does this sound right ??
Thanks for any help, anyone could give.
Damon
Old Apr 30, 2005 | 07:08 AM
livewire's Avatar
8th Gear
Help
Please !!!!!!!!!!!!!
thanks Damon
Old May 8, 2005 | 07:42 PM
glynn's Avatar
go with the water pump bearings. my mates 3ootdi had new belts and 1 month later bearings went on water pump lost all water pressure thru bearing and belt jumped off doin 70 mph on m6 not good at all.... probably best to change water pump..before any more damage
glynn
roverdisco1017
Jun 28, 2012 06:48 PM
shampro
Audio/Visual Electronics
Aug 23, 2009 09:21 PM
sesese
Aug 9, 2009 02:23 PM
teletechlpi
Nov 6, 2006 09:04 PM
landyrangie
Dec 22, 2005 06:09 PM
