Discovery 2 low beam Headlights out.
Old Nov 2, 2013 | 07:34 AM
redspyder's Avatar
Default Discovery 2 low beam Headlights out.
Hello, I went out last night and my low beams were on for about 2 minutes and they just both went out. All the other lights work, as do the high beams. I checked the fuses for each side and they both are OK. I have 2 questions:
1. Is there a relay for the low beams, if so where is it, or which one is it?
2. If there is no relay, is it the switch on the steering ?
I have not replaced the bulbs but I doubt they both blew out at once. I will change one out today.
Thanks in advance
Disco 2, 137,000mi
Old Nov 2, 2013 | 10:45 AM
Paul Grant's Avatar
Might be your headlight switch.
Old Nov 3, 2013 | 08:54 AM
Check for a blown fuse, I believe there are 2 one for high beams and one for low beams.
Old Nov 4, 2013 | 11:31 AM
redspyder's Avatar
Hello, there is a fuse for each high and low beam for each side, so 4 all together. I replaced the bulbs and that was it. Silly me, I guess I was driving along with one light out for god only knows how long, and the other one blew out.
I am still curious about the relays, which ones are they or do they exist at all. I can not find any mapping of the relays at all. I understand that they do not want you to pop out the ABS relay but I would like to label all of them.
Thanks
2003 Disco II 137,000 mi, engine resealed, etc
86 Porsche 911
66 Healey 3000
74 Norton 850 Commando
Rover Rog
May 26, 2019 12:33 AM
schwaggy
Jul 8, 2014 02:23 PM
haverhillguy
Feb 11, 2010 08:24 AM
tsuami1
Mar 9, 2009 07:33 PM
LR4LIFE
Nov 6, 2007 10:23 PM
