Discovery 300 tdi
Old Jan 13, 2010 | 03:10 AM
phelps69's Avatar
4th Gear
Thumbs up Discovery 300 tdi
Hi, new here, so bear with me as I am not sure of the protocol. I have a 1990 Disco heavily modifieed with a 300tdi lump in it, standard turbo with a burton intercooler. Coming back from an off road event I noticed that all of a sudden the whistle from my turbo got a little louder and the power had dropped off slightly. It still drove but with a less power when I accelerated. I have a boost guage which was still showing normal boost, but with less power.
Could anyone add some advice as to what could be the problem, it would be appreciated
thanks
Scott
Old May 29, 2010 | 07:38 AM
pepi's Avatar
Even with boost pressure reading normal you cold still have a leak in the system it will just take more effort for turbo to build pressure.
Look for the whistle with a lengh of hose pipe stuffed to your ear!
cheers pete
Old May 29, 2010 | 07:43 PM
You have a leak somewhere between the turbo and the intercooler.
Old May 29, 2010 | 09:42 PM
tornado_735's Avatar
I have a really good friend in England who has a 300tdI in his Range Rover.
I will send him the link to this, and see what he says.
Hi Frank!!!
Old May 30, 2010 | 06:16 AM
britpart81's Avatar
Hi Scott, could be a leaking turbo hose, but also check for a blockage in the exhaust system, sometimes the exhaust boxes colapse internally, perhaps it was whacked while you were off-road? check also the turbo boost line to the injection pump isn't cracked/leaking, these are prone to going brittle with age, hope i've been some help!
Old May 30, 2010 | 06:29 AM
britpart81's Avatar
Hi Aaron! good to hear from ya!
Yep, if there's one thing i know about it's 200/300tdi's (that & wrecking my RRC!) the vast majority of Land Rovers in the UK have this engine fitted, it's a very robust unit, easy to get more power from too, the Bosche VE injection pump is a piece of cake to tune up, i think it's also used in some of the trucks in the U.S.?
Old May 30, 2010 | 09:11 AM
There are no diesel Disco's in the US.
dirkha
Feb 10, 2021 06:44 AM
spuggy
Jan 14, 2014 01:46 PM
maxspeedingrods
Apr 21, 2011 11:11 PM
DAN386H
Feb 21, 2011 11:33 PM
disco-112
Feb 12, 2011 11:31 AM
