Discovery 4.0 in 2004 Range Rover
Old 08-09-2019 | 11:03 AM
jdbayer's Avatar
Default Discovery 4.0 in 2004 Range Rover
First off I know this is a strange question. I have a chance to pick up a pretty nice 2004 Range Rover for a steel because the engine is gone. I have a running 4.0 out of my 2001 D2 and figured if it would work I could have a nice RR for a good price. Do y'all know if this is even possible? I know anything I possible if you put enough time in it but I am not looking to do any fabrication. In a perfect world I could pull one engine and drop the other in.
Old 08-09-2019 | 11:55 AM
Best4x4's Avatar
It will sadly never work. The 04 was BMW 4.4L powered & the front diff is actually attached to the oil pan & the axle goes thru it. With that said you should be able to find a BMW 750 if I’m not mistaken with the same engine, but that would only work if you needed the block. If the entire RR BMW 4.4L is gone you’d have to get one from a wrecked 03-05 RR.
Old 08-09-2019 | 12:31 PM
ahab's Avatar
750 is a V12, that might be even harder 740 should have the 4.4 V8.
Old 08-09-2019 | 12:54 PM
jdbayer's Avatar
Well damn. Thanks for the info.
Old 08-09-2019 | 01:12 PM
Taylorwhit0912's Avatar
4th Gear
Does anyone know what this part is called?
Old 08-09-2019 | 02:38 PM
Best4x4's Avatar
Yeah I’m not a BMW guy, but now that I think about it I’m thinking the ghetto BMW we went to pull the 4.4L block out of at the junk yard was a 740 with 750 badges. It was totally ghetto with bling wheels. The block ended up being locked up so we dove into an 05 RR that had one valve cover gone & a chain hanging out. However the block was fine. Friend is cruising around perfectly fine to this day on it!
AppliedAquinas
Range Rover L322 (3rd Gen)
03-03-2019 09:32 AM
incharleston
06-11-2017 03:14 PM
srvguitarslinger
07-09-2012 01:56 AM
juliogrullon
04-22-2007 06:24 AM
xiantifik
ROAMING WITH FRIENDS
02-15-2007 02:07 AM
