Discovery 4.0 in 2004 Range Rover
Old Aug 9, 2019 | 10:03 AM
jdbayer's Avatar
Default Discovery 4.0 in 2004 Range Rover
First off I know this is a strange question. I have a chance to pick up a pretty nice 2004 Range Rover for a steel because the engine is gone. I have a running 4.0 out of my 2001 D2 and figured if it would work I could have a nice RR for a good price. Do y'all know if this is even possible? I know anything I possible if you put enough time in it but I am not looking to do any fabrication. In a perfect world I could pull one engine and drop the other in.
Old Aug 9, 2019 | 10:55 AM
Best4x4's Avatar
It will sadly never work. The 04 was BMW 4.4L powered & the front diff is actually attached to the oil pan & the axle goes thru it. With that said you should be able to find a BMW 750 if I’m not mistaken with the same engine, but that would only work if you needed the block. If the entire RR BMW 4.4L is gone you’d have to get one from a wrecked 03-05 RR.
Old Aug 9, 2019 | 11:31 AM
ahab's Avatar
750 is a V12, that might be even harder 740 should have the 4.4 V8.
Old Aug 9, 2019 | 11:54 AM
jdbayer's Avatar
Well damn. Thanks for the info.
Old Aug 9, 2019 | 12:12 PM
Taylorwhit0912's Avatar
4th Gear
Does anyone know what this part is called?
Old Aug 9, 2019 | 01:38 PM
Best4x4's Avatar
Yeah I’m not a BMW guy, but now that I think about it I’m thinking the ghetto BMW we went to pull the 4.4L block out of at the junk yard was a 740 with 750 badges. It was totally ghetto with bling wheels. The block ended up being locked up so we dove into an 05 RR that had one valve cover gone & a chain hanging out. However the block was fine. Friend is cruising around perfectly fine to this day on it!
AppliedAquinas
Range Rover L322 (3rd Gen)
Mar 3, 2019 08:32 AM
incharleston
Jun 11, 2017 02:14 PM
srvguitarslinger
Jul 9, 2012 12:56 AM
juliogrullon
Apr 22, 2007 05:24 AM
xiantifik
ROAMING WITH FRIENDS
Feb 15, 2007 01:07 AM
