Which Discovery do I Purchase?
RE: Which Discovery do I Purchase?
If you are looking for the best used Disco, the 2004 model offers the best capabilities without the oil pump problems of the 2003 model. Late 2001/early 2002 through 2003 model Disco's do not have the center differential lock hardware in the transfer case. If you plan to off road this hardware is arguably essential equipment. the 1999 to 2000 Disco's are cheap and have a long list of improvements over the Disco I models.
Be aware any used Rover is going to need a bit of maintenance to be brought up to standard. Oil change, new tires and other parts may be needed. Whatever Rover you choose, make sure you sleep on the decision a night or two (unless it is in pristine condition). Of the several vehicles I owned, the Disco is my favorite by far.
Cheers,
Pete
Cheers,
Pete
Each used Rover out there is going to have some unique area of neglect, however major or minor. Disco I have better approach and departure angles and come with the center differential lock handle from the factory. My buddy's 1998 Disco I seems just as capable as my 2000 Disco II. Of course mine looks better and has a bit more legroom.
Cheers,
Pete
Cheers,
Pete
