Discovery full gas tank
Old Apr 24, 2009 | 05:26 PM
AK Rover's Avatar
Have you done research on the 2003 model years? Are you aware of the oil pump issues that go along with the 2003s? The oil pumps fail and destroy the engine. The only fix is a new engine for about $7000. Get the VIN and check it against the bad VIN range that is somewhere on this forum. The subject has been covered about 1 million times so finding it shouldn't be too difficult.
I would suggest looking at a 2004 instead of the 2003. It's the same engine less the oil pump issues and it has CDL standard in case you want to off road with the truck. The 2003 requires rebuilding the transfer case to add the center differential lock.
Old Apr 24, 2009 | 07:06 PM
khuds308's Avatar
don't buy a rover. simple as that.
Old Apr 24, 2009 | 07:33 PM
Originally Posted by Torancis_LR
UPDATE:
Just test drove a 03 Disco! It has unbelievable power. Coming from a Jaguar XJ8 with 4.0 liter, the Disco 4.6 has much more power. I'll keep you posted!
The 4.0 and 4.6 are the exact same engine, the 4.0 in a DII has 188 HP and the 4.6 has 200 HP.
Old Apr 24, 2009 | 07:40 PM
Disco_Fever's Avatar
UPDATE:
Just test drove a ... Disco! It has unbelievable power. ...I'll keep you posted!
Never thought I'd read that! Are you sure you test drove a Land Rover Discovery? LOL
Old Apr 24, 2009 | 08:53 PM
grussell's Avatar
I filled up today with Quick Trip premium @ 2.16 a gallon.
Old Apr 24, 2009 | 09:08 PM
$2.28 at Speedway today, only 17,200 more points and I get a $50 gas card.
Old Apr 24, 2009 | 10:07 PM
Jupiter Rover's Avatar
03/04 have the 4.6L. My 2003 has a ton of power. A Lot of low end torque. Ponies are kinda low, but I consider hp speed and tq "power".
Old Apr 25, 2009 | 02:54 PM
Torancis_LR's Avatar
I was talking about the 4.0 in the Jag that has 290 HP. But the engine it self has some problems which is really slow. so even the 200 HP Disco felt more power.
Old Apr 25, 2009 | 04:55 PM
You're probably feeling the 300torque at 2600RPM.
Old Apr 25, 2009 | 06:46 PM
The Jag 4.0 is the same as the Rover 4.0.
But if it has some issues then I better understand.
Land Rover owns Jag.
