Discovery II “Door lock / Ignition / key” Swap
Old Feb 25, 2019 | 09:24 PM
Jacob Martin's Avatar
Default Discovery II “Door lock / Ignition / key” Swap
So due to unfortunate circumstances, I have to change my driver door handle/lock, my ignition, and my key on my 2002 Disco II. I already have a donor vehicle that the ignition, key and door latch are all coming from.
One of my main concerns is that once I change out the ignition and my door latch is that will it all operate as normal? Are there any types of reprogramming that will need to be done? Or once I get everything installed, can I just insert the key into the door lock and all of the other doors will unlock as usual? Any advice or guidance would be greatly appreciated.
On another side note, I’m assuming that I will have to reprogram the fob for the new key, but that is not a big deal. Thanks in advance guys
Old Feb 26, 2019 | 05:34 AM
mln01's Avatar
No need to worry about reprogramming the door lock. Nothing in the door handle is electric or electronic. It connects via a rod or pin to the actuator, which is where the electrical switch is that connects to the body control unit (BCU). The actuator will remain intact, but even if you swapped it out no reprogramming would be needed.
I recommend that if you're going to have the door lock apart that you upgrade the rod/pin. They're a known weak point. Abran sells an upgraded version linked below, and his pics show where the factory pin breaks and where the replacement fits into the door handle. I upgraded mine many years before Abran's version was available using a file and a drill on a 20d nail.
https://carrs4x4.com/collections/new...etime-warranty
Old Feb 26, 2019 | 06:25 AM
zuke's Avatar
I would disagree but correct me if I am wrong. After the swap he would have 2 choices to make his FOB work.
1. Swap out the circuit boards from the old FOB to the new FOB.
2. Reprogram the new FOB.
Old Feb 26, 2019 | 06:53 AM
mln01's Avatar
Yeah, I was speaking to the door handle only, not the keyless entry "fob."
Old Feb 26, 2019 | 07:13 PM
GCBurke's Avatar
You should be good.....you can pull the key out of your original fob and put the key from the donor car fob in it. No programming should be needed. or swap the guts out of the fobs....either way will work.
Old Feb 26, 2019 | 09:00 PM
Awesome, thanks for the help guys! I’ll be putting it in tomorrow after work and if I have any questions, I know who to ask!
trex_7
Oct 8, 2017 09:46 PM
LandroverNi
Sep 22, 2016 09:50 PM
jamanta
Sep 4, 2015 02:33 PM
Steven James
Apr 9, 2015 05:21 PM
AZRover
Feb 10, 2013 12:00 PM
