Discovery II, codes PO171 & PO174
Old Dec 11, 2008 | 10:04 AM
philiplarson's Avatar
Default Discovery II, codes PO171 & PO174
2000 Discovery II with 82,000 miles
I have two codes PO 171 and PO174. where do i look, MAF or plugs and wires??
Old Dec 11, 2008 | 11:33 AM
AK Rover's Avatar
Default RE: Discovery II, codes PO171 & PO174
P0171 - Oxygen Sensor System Too Lean Fault Bank A
P0174 - Oxygen Sensor System Too Lean Fault Bank B
Not really sure where to tell you to start to look to troubleshoot the problems. Thought I would post what those codes mean so someone else can chime in with ideas to fix the problem.
Old Dec 11, 2008 | 11:52 AM
redhotbuzz's Avatar
Seafoam It
Old Dec 11, 2008 | 12:40 PM
jkid's Avatar
Probably the MAF sensor, make sure you get a Bosch one, not aftermarket. How often does it come back after you erase it? If not too often, I would hold off until I got a 3rd or 4th gear ratio code too. Also look for vacuum leaks after the MAF sensor.
Old Dec 11, 2008 | 01:58 PM
Thank you
Old Dec 11, 2008 | 02:00 PM
Seafoam, is this gas treatment & who carrry this product?
Old Dec 11, 2008 | 03:18 PM
Switzer's Avatar
ORIGINAL: philiplarson
Search for seafoam on this forum, there are several pages worth of how-to's and general information on it.
The MAF is the most likely culprit. www.roverlandparts.com sells used ones.
Cheers,
Pete
Old Dec 12, 2008 | 11:02 AM
PM me with your tele number and we can talk more about how to check and what to replace.
Old Dec 12, 2008 | 08:42 PM
ORIGINAL: Disco Mike
And for the rest of us who want to know what to do next?
Old Dec 13, 2008 | 08:17 AM
When both codes show up together, if the MAF hasn't failed, then I would look for air leaks from the filter box to the t/body.
