Discovery II, codes PO171 & PO174
Old Dec 20, 2008 | 12:14 PM
philiplarson's Avatar
Default RE: Discovery II, codes PO171 & PO174
I filled up with hi test(93)and used Seafoam. Instead of the service engine light coming on in about 10 to 12 miles. I now have about 65 mileson the LR and no light. It would appear that the codes 171 & 174 wasfouled injectors. Thank you for all you help.
Old Dec 31, 2008 | 06:19 AM
After two bottles of Seafoam, the SEL came on again with an odd code for 4th gear. I ordered a MAF and installed last night. This would appear to be the problem. I am not a part replacing type person. But, with the help of this forum, I was able to troubleshoot and repair without throwing parts at the problem. Thanks fore the responce and help.
Phil
Old Dec 31, 2008 | 09:59 AM
Per your last post, I got the impression you don't always use high test, if that is the case, with the new year coming tomorrow, it is time to change your habit.
Old Dec 31, 2008 | 10:23 AM
I will be using high test from now on. Thanks again for the great support.
Phil
Old Jul 16, 2009 | 10:06 AM
jayv's Avatar
Smile
Phil
I have been getting these codes too p0171, po174 for about the last month. i diligently went through every vaccum line and checked for leaks, replaced the aire filter (needed it anyway) and the MAF O ring. in the mean time i replaced the plug wires with magnacors (took off the IM). I felt confident that there were no leaks.
so, i replace the MAF 217.00 at AB. ......no more codes.
this site and LRRf gave me good ideas on how to diagnose. thanks!
Robover01
Oct 30, 2009 08:02 PM
carl.plansky
Aug 10, 2008 08:31 AM
D2Steve
Jul 1, 2008 07:37 PM
LandRoverq
Nov 17, 2006 11:37 AM
cottonpatchweims
Jan 7, 2005 12:50 PM
