Discovery II Cracked Block, what should I do?
Old Mar 18, 2013 | 10:32 AM
drowssap's Avatar
part it out and buy another
Old Mar 18, 2013 | 02:00 PM
SuperSport's Avatar
#/watch?v=KSzI4rdrNo8
Old Mar 18, 2013 | 02:02 PM
SuperSport's Avatar
Oops, did I accidentally post that?
Old Mar 18, 2013 | 04:03 PM
Willie00d2's Avatar
Mine is the same color. Must be another frustrated Land Rover owner. I think the discovery will be a rare vehicle on the road because they cost so much to rebuild, it's not worth it so they will be junked.
Willie
Old Mar 18, 2013 | 05:21 PM
jfall's Avatar
So the Discovery engine is this Buick 215 CID thing from the 1960's
Same bolt pattern?
Then is the Discovery II / Discovery I and most all Rover bolt pattern actually a GM or Chevy bolt pattern?
Would that not portend that the Duramax diesel could be put in?
If the crank pattern is the same for the flex plate and the bolt pattern is the same then...
Old Jun 5, 2013 | 12:17 PM
Charlie_V's Avatar
Seems like this thread ended. But I am wondering what you did with your disco? I hope you put a new block in it. They are so easy to fix and parts are so plentiful it seems like a vehicle that, with mechanical skills, you can keep going for a very long time.
Old Jun 5, 2013 | 12:18 PM
Charlie_V's Avatar
If I had one like yours and didn't want to put a new block in it, I'd certainly keep it for parts if you have room.
x1124x
Aug 12, 2017 09:25 AM
DiscoArt
Nov 11, 2009 03:30 PM
twmj1953
Jun 21, 2009 03:52 PM
unstable
May 28, 2009 10:25 AM
37chambers
Oct 28, 2005 09:03 PM
