Discovery II ECU Replacement
Old 03-27-2017 | 05:18 PM
Roflcopter's Avatar
Default Discovery II ECU Replacement
I have an 2002 with the 4.0L engine. I had an issue with a o2 sensor harness wire that had previously been "repaired." Turns out, the mechanic mixed the wires around and sent (12v) to the ground for the signal return of said o2 sensor(max 1 volt). It fried the ecu to where I have no movement on said o2 sensor, though it runs and drives. The issue is I can't pass emissions with the check engine light on. I have gone through the complete testing procedure. It is a bad ECU. No bad o2 sensor, wiring, etc.
Anyways, I have received the correct replacement ecu( with SAI) from a running rover with no issues. I read that it will not start without the accompanying BCU, which I did not grab. And will lose the current mileage even if I did.
So, Which scan tools will let you "Learn/Reprogram" the ECU so it will start and help save the mileage?
Old 04-27-2017 | 10:33 AM
brmadsenad's Avatar
I've looked into this, but haven't quite nailed down all possible answers. From other threads, these appear to be options:
(1) Dealership can do it, not totally clear how willing or cost. Call and ask is only option.
(2) Online services can take old ECU and re-program replacement ECU. You mail them stuff, then send back a "plug and play" ECU. I've talked to AES Modules and ECU Technologies. Prices from $350 to $850.
(3) Some threads talk about buying a diagnostic tool (Nanocom or Hawkeye) and using it. I've asked Dusty1 for clarification. Jafir would know, too. But the Nanocom manuals seem to say it can't be used to re-program DII ECU . . so, I dunno.
Let me know if you figure this out, please.
Old 04-27-2017 | 01:00 PM
brmadsenad's Avatar
Huh. A dealership service center in Utah just told me it is not possible for them to reprogram an ECM to a new vehicle. He simple said that it will only every work in one vehicle, no fixing it.
Now, I am pretty sure that is just not true, but at least this dealership won't do it.
To re-program a non-vin-locked ECM was only $130.
Old 04-27-2017 | 02:19 PM
abran's Avatar
I have synced used ECUs to vehicles with my autologic, but its too expensive to buy far that use.(12-16K)
brmadsenad (04-27-2017)
Old 04-27-2017 | 02:28 PM
brmadsenad's Avatar
Default Thanks,
That's good to know, Abran.
​​​​​​I beleive the dealership CAN do it, but the one I talked to won't or doesn't know how.
Abran, if it's possible to send you ECU/additional parts and get a replacement ECU programmed to a new VIN/vehicle??
Old 04-27-2017 | 09:41 PM
abran's Avatar
I need the vehicle present. The only other way would be if I have a complete parts car and you send your BCM, Instrument cluster, and ECU and I could sync installed in my car.
Old 04-27-2017 | 09:56 PM
brmadsenad's Avatar
Hey, this sounds promising:
https://landroverforums.com/forum/di...program-76697/
Assuming you can get hands on a Nanocom, at least.
Old 04-28-2017 | 01:08 PM
zuke's Avatar
Default I'll take "Doing **** the hard way" for $200, Alex
1. Go to Ebay
2. Buy ECU, BCU, Gauge cluster for $100
3. Spend 45 minutes installing
4. Drink beer
JUKE179r (10-29-2019)
Old 04-28-2017 | 01:26 PM
brmadsenad's Avatar
I'll check it out, Zuke. Thanks for the tip.
How does the key work if you swap cluster, bcu, ECU?
Old 04-28-2017 | 02:07 PM
zuke's Avatar
Key works the same but your FOB would need reprogrammed. I just use my key to lock and unlock. I live in BFE so I rarely lock my cars.
Quick Reply: Discovery II ECU Replacement
