Discovery II ECU Replacement
Old Apr 28, 2017 | 02:08 PM
brmadsenad's Avatar
Awesome. Very appreciated.
My fob buttons are all busted anyway.
Old Apr 28, 2017 | 03:22 PM
zuke's Avatar
Default Step 5
While you are on eBay, spend another $8 for a new fob case
Old Apr 28, 2017 | 11:37 PM
jfall's Avatar
Untangle the wiring.
Get an ECU from a junk yard or eBay.
Make sure it is SAI or non SAI depending on your situation.
And that's bout it.
Old Apr 29, 2017 | 08:32 AM
brmadsenad's Avatar
Jfall -
Unless you mean get an ECU, BCU, and Instrument Cluster from the same vehicle, I don't think your plan is as simple as it sounds.
If you put a different ECU in your truck, you will have to program it to "match" the BCU. This requires special equipment or paying a shop.
Old Aug 8, 2018 | 09:48 AM
1badtoad2's Avatar
Default 2002 discovery 2. Changed ecu,bcm, instrument cluster.
Originally Posted by zuke
1. Go to Ebay
2. Buy ECU, BCU, Gauge cluster for $100
3. Spend 45 minutes installing
4. Drink beer
Did as others said installed, connected negative, turned key on position 2 for 10 minutes, turned off wait 2 minutes and started right up runs great, but when put in any gear , automatic lol,. The headlights flash fast. Any body have any ideas. I think it's the sercurity system not communicateing . Would appreciate any information
Old Aug 8, 2018 | 10:12 AM
Fast951's Avatar
Originally Posted by abran
I need the vehicle present. The only other way would be if I have a complete parts car and you send your BCM, Instrument cluster, and ECU and I could sync installed in my car.
I have all three of these items from a known working vehicle (2003 SE) in my possession. I think the odometer is 134K miles. PM me if interested.
Old Oct 28, 2019 | 03:59 PM
Lr2gal's Avatar
Default Help with 2008 lr2
Hi
Glad I found this thread...! I have a 2008 lr2 that has been running very badly 3 misfires (1,2,5), won't accelerate, burning gas like I do coffee, and tons of parts replaced (maf, fuel regulator, spark plugs, coils, battery, and more) and no proper diagnosis by the dealer. It stalls on cold start up and you cannot run the ac unless it's been driving a while or it will stall again. Been in shop 3x this week alone. Finally someone says it seems to be the ecm is not working because the 14 fault codes I get all have a problem to do with not receiving communication etc...
I am running out if money and desperate at this point. How can I replace the ecm the most cost effectively? Can I do this myself without the dealer?
Any help is greatly appreciated I really love this car :/thank you for your help.
Old Oct 29, 2019 | 12:39 AM
toofaroffroad's Avatar
Replaced my ECU a few years back with a used one from wrecker. did not replace BCU...or anything else. Just plugged it in and had a shop reprogram it which laughingly took about 2 minutes. I believe the shop used some sort of BMW scanning tool. Also The Hawkeye works and maybe the nanocom. I know that doesn't really answer your question but just wanted you to know that it can be done easily.....with the right tool and there is no need to replace anything else. I had the same worry. Good luck.
Oh and FYI, I replaced mine because of a bad signal that was being sent through my O2 sensors. I spent almost $1000 and 2 months of bull**** trying to track this issue down. The ECU switch fixed everything. Also gave me more MPG and horsepower. Ok the last part was a lie,
Old Nov 5, 2019 | 08:06 PM
Rorybuckminster's Avatar
4th Gear
The truck didn’t run after the switch or did it cus ied have to drive mine to a shop in another state to have it reprogrammed.do all shops know how to reprogram an ecu? I feel like I call a local LR shop and they act as if I’m speaking gibberish
Old Jul 19, 2021 | 02:10 PM
Hfg solo's Avatar
Default Help me
And that's bout it.
can this work to bypass sai
