Discovery II Electrical Library & Diagrams
Old Jun 28, 2012 | 09:08 PM
Enrique5's Avatar
Post Discovery II Electrical Library & Diagrams
Anyone know where I can get the Discovery II Electrical Library and Electrical Diagrams? I'm trying to repair a hacked up harness on a 2004 d2.
Old Jun 28, 2012 | 09:15 PM
jafir's Avatar
Old Jun 28, 2012 | 11:13 PM
nahtanoj's Avatar
the link in my sig takes you to all the downloads as well. i just had to go digging through the electrical diagrams for a window issue.
Old Jun 29, 2012 | 05:17 AM
and here are some more links, including the ECU manuals which are not in the RAVE. When looking at circuits, those tiny numbers are the connector numbers, switch over to electrical library and they have photos of the location and pin outs for whole connector, on Discos that have never seen daylight, much less the trail or an oil leak. You'll also want to look at the start of the manual for the color code (like K = pinK, U = blUe, etc.)
Old Jun 30, 2012 | 01:02 PM
Enrique5's Avatar
The rave and other electrical electrical diagrams I keep finding are labeled up to 2003MY. I'm working on a D2 where wires have been tampered with. The problem at the moment is that on the plug on my rear LH O2 sensor (T185) pin 4 is suppose to go to ECM plug C0635 pin number 7. Instead it's going to pin 15. I'm wondering if this is, because this diagram is 03 or that the wire was swapped. However, this particular wire does not look like it's been tampered with.
Old Jun 30, 2012 | 01:20 PM
Or maybe some plugs switch from one side to another. Attached page on the CPU shows pin 7 to be an output for heater on downstream O2, while pin 15 shows to be sensor signal for the upstream O2. I don't think they had two different CPUs.... Do wire colors in harness match drawing?
Old Jun 30, 2012 | 01:21 PM
Enrique5's Avatar
no the schematic is right. My helper on the other side of the continuity tester is getting cross eyed LOL. The pin is in the right place.
Old Jun 30, 2012 | 01:23 PM
nahtanoj's Avatar
hmm, pin 15 should belong to the front O2 sensor. the drawing should be right for all D2's up to '03.
have you checked the front wire to see where it goes? perhaps they got swapped at the sensor end?
is that the only one out of place?
Old Jun 30, 2012 | 01:24 PM
nahtanoj's Avatar
ahh good to hear.
jon
Old Jun 30, 2012 | 01:30 PM
the most dangerous of electrical helpers is the color blind one.....
