Discovery II suspention question
Old Apr 30, 2005 | 08:54 PM
basquiat's Avatar
4th Gear
Default Discovery II suspention question
Greetings
I just had a question concerning a 99 Disc II. I have had the vehicle for 2 yrs + with no problems. Lately though i have noticed that whenever the car is parked, it lowers itself in the rear. At times it will do it while i am driving. was wondering if this is something to be concerned about, unfortunately there are no LR dealerships near my home. The nearest dealership is approximately 6 hrs away. Thank you in advance for any assistance, knowledge you can share
Bas
Old May 1, 2005 | 04:55 AM
Bene's Avatar
Default RE: Discovery II suspention question
im no expert, but it sounds like your having airbag problems. i woudl recomend saving yourself a lot of time (and asprin) and swap thgem out for conventional springs. they're somewhere at www.roversnorth.com
Old May 1, 2005 | 11:41 PM
Newfoundlandrover's Avatar
Yep,sounds like your air bladders are leaking.This is a pretty common problem with Discoverys and the quickest and cheapest way to fix it is to remove the air ride setup and replace with coil springs.When I was shopping for my Discovery,I actually settled for a 5 pass with springs just to avoid the air bladder setup that comes on the 7 pass.(I got tipped off ahead of time by a LR Tech). From what I hear the swap is pretty simple and inexpensive.
Old May 2, 2005 | 03:07 AM
basquiat's Avatar
4th Gear
Thank you
i will look into it, i guess now i know were that hissing sound is coming from -). hehe
I appreciate your quick response.
Old May 2, 2005 | 04:50 PM
mmeyer's Avatar
if it goes out while driving, parked, etc...it could also be your ECU Slabs
Old Jun 21, 2005 | 11:21 PM
2000DiscoIICanada's Avatar
I had the same problem with my suspension. I wanted to maintain all of
the factory functionality so I did not want to switch to coil spring suspension.
I found a great company out of Cape Canaveral Florida that sell replacement
bags http://www.arnottindustries.com/part...ies_yid48.html
And by the way...they have a lifetime warranty! I had the first of the two rear bags
replaced at the dealer at a cost of $500 cdn plus install. When the second bag started
leaking, I started looking around and found these guys. Their price with duty, tax, and
shipping to Canada was less than half! The factory bags only come with a 1 year warranty.
I hope this helps
Best Regards,
Tom
Old Jun 23, 2005 | 12:52 AM
Bait's Avatar
I second Tom's source in FL. They produce bellows that are superior to OEM and less $. They can be a little tricky to install. All the bellows are the same except for the D2 rear SLS bags.
Old Jun 23, 2005 | 02:44 AM
Bene's Avatar
out of curiosity (and while we're on the subject) han you get lifted bags?
Old Sep 6, 2005 | 12:37 AM
htxb's Avatar
ORIGINAL: Bene
does anyone know any less expensive ways to convert the rear suspension to this type of set-up?
i'll probably end up just buying replacment bags from the link Tom gave...Thanks, Tom!
are the rear bags easy to replace? does arnott industries send installation instructions or is there a how-to somewhere?
Old Sep 6, 2005 | 05:38 PM
htxb's Avatar
My cousin found a site that sells both the conversion kits and replacement parts for the air suspension system and has better prices than the 2 sites listed above:
http://www.strutmasters.com/land-rover/index.htm
Does anyone have any experience (good or bad) w/these guys?
