Discovery II suspention question
Old Sep 10, 2005 | 08:39 PM
modyfyit's Avatar
Default RE: Discovery II suspention question
yes the rear bags are very easy to replace..
1. let your bags deflate as much as possible.
2. jack truck up as high as possible
3. (your choice to take off the tire)
4. there is 2 clips that just lift off the top of the bags, screwdriver or prybar (try to keep them if the replacement bags dont come with them)
5.pull the bags down out of the holder (at this point you might want to cut the zip tie on the airline )
6. take a 10mm wrench and carefully undo the air line (dont strip this)
7. deflate bag all the way
8. turn bag 90 degress and pull off the holder
9. repeat steps to reinstall
hope this helps.. ask if you have and questions
Old Feb 1, 2006 | 11:55 AM
tetongolf's Avatar
Are these steps that you listed for a Discovery II? I just bought a new set of air springs and was going to replace them. Are there any special tools needed? Any special procedures? Do you have to jack it up really high to get them out? Any feedback would be much appreciated.
Thanks!
Michael
Jackson, WY
Old Feb 2, 2006 | 06:19 PM
Lillebiff's Avatar
3rd Gear
And if you go to this link, you will see some pictures
http://www.disco2.tk/
Best regards from Norway
Hans-Ole
Old Feb 2, 2006 | 06:31 PM
Lillebiff's Avatar
3rd Gear
Sorry, forgot to tell you: it is in Norwegian, but you can see out of the pictures, and it is quite easy to change them! It is under this homepage, just scroll down to the right pictures...
http://home.online.no/~ksskaret/disc.../lift/lift.htm
Good luck!
H-O
JBCO
May 24, 2015 12:12 PM
ek5usmc
Nov 25, 2008 11:45 AM
lior3
Apr 30, 2008 03:21 AM
xb70valkarye
May 9, 2007 06:56 PM
hotchicken
Apr 3, 2005 07:04 PM
