Discovery Life Expectancy
Old May 27, 2009 | 10:33 AM
kissdisco2000's Avatar
3rd Gear
Default Discovery Life Expectancy
I am a newbie, so new I am buying my first today. Its a 2000 with 120,000. The previous owner is a certified Land Rover mechanic from England. As long as I take care of this vehicle, how many miles can you get out of this engine?
Old May 27, 2009 | 10:50 AM
jycsalas's Avatar
Is he the original owner?
Old May 27, 2009 | 02:06 PM
3rd Gear
No he is not! He has owned it from 90,000 miles. He was working for Land Rover at the time when he bought it from the original owner who had it from day one.
Old May 27, 2009 | 03:36 PM
As long as you take care of it you can expect 300,000+ miles without a enigne overhaul.
If you beat the crap out of it you can expect 200,000 miles.
Old May 27, 2009 | 05:08 PM
sloppyjoe's Avatar
mine was babied from the first owner till 45k miles. it now has 53k on it and i take care of my vehicles. i use them, but they are cared for. so i fully expect the steel from my chassis to rot away long before my engine goes.
Old May 27, 2009 | 06:14 PM
oljohnboy's Avatar
I would say take a good look under it. I think that says alot. are there lots of leaks? rust? dry rot on rubber? i think a vehicle is a lot like a shoe, it tells where its been on the bottom. if the previous owner neglected these issues, then that tells you something. im not saying if you have a leak that its bad, it is a rover! by the way my analogies may suck!
Old May 27, 2009 | 06:22 PM
sloppyjoe's Avatar
mine was spotless until i got hold of it. it looked like it was factory fresh,,,, not so much now. a winter of trails and mud have given the chassis a nice patina
Old May 27, 2009 | 06:45 PM
oljohnboy's Avatar
i bet! i think i am lucky, mine does not leak anything. and no its not empty! i had a power steering suction hose leak but i have fixed that. i havent even been able to really see what mine can do yet, i think that is when i will really be hooked!
Old May 28, 2009 | 02:59 PM
apcollin's Avatar
what are you basing that on? Land Rover Owner's International magazine would disagree with you. check out there 20th Anniversary of the Discovery article
but anyway, as someone else mentioned the body will probably return to the earth before the engine quits
Old May 28, 2009 | 03:41 PM
okdiscoguy's Avatar
I would tend to say that Spike is a little generous with his mileage. I would say at 200K they need an overhaul. This is with replacing head gaskets a couple of times and various seals along the way. I have 120K on my bottom half, and I needed new bearings. Spun them in when I did my front cover. It still needs a full tear down, though...
