Discovery Light Bar!? Putting it to a Vote...
Old May 18, 2011 | 10:02 AM
DiscoBenjamin's Avatar
Default Discovery Light Bar!? Putting it to a Vote...
Was just cruising ebay and found this:
Land Rover Discovery I II III Light Bar NEW Four Lamps | eBay
Pic is also attached
Whats the concensus?
Attached Thumbnails Discovery Light Bar!? Putting it to a Vote...-discovery-light-bar.jpg
Old May 18, 2011 | 10:30 AM
dcarr1971's Avatar
Can you change out the bulbs to higher wattage versions without causing problems? (i.e.- melting the housings/wiring.)
I think I would want to know if I could get a different beam pattern for two of them too. You can't use them on-road, but being able to see further out than a driving light will project is still nice when off-road in open areas...
Old May 18, 2011 | 10:31 AM
hilltoppersx's Avatar
it's just some generic lights. i don't think it's worth $20. It won't fit right and will look like crap IMO.
Old May 18, 2011 | 10:36 AM
yloDiscoII's Avatar
NO, I like the look but too expensive.
Old May 18, 2011 | 11:02 AM
thospb's Avatar
Anything that mounts to the surface may wear through the paint from vibration. Something to consider if you plan to ever remove it. Also, they ship "by default" the blue lens. Check your local laws, but where I live Blue Lights are reserved exclusively for Law Enforcement. Instant ticket.
Old May 18, 2011 | 11:20 AM
drowssap's Avatar
I saw one up close on a liberty, same manufacture only it had round lights.
I have to say it look like something you would get a k-mart in the peal and stick isle.
JMO
Old May 18, 2011 | 12:27 PM
JMO
exactly what i figured.
Old May 18, 2011 | 12:43 PM
yloDiscoII's Avatar
Jeep Liberty factory light bar....eerily similar
Old May 18, 2011 | 01:56 PM
salve7's Avatar
When I had my disco I considered a light bar like the one above, however I changed my mind after researching the distributor. The Liberty light bar is made by a different company than the one in the ebay ad and wouldn't be a bad idea if you don't mind the look other than the fact that it is curved to fit the top of a liberty and not a rover. I was going to go with a gutter mounted light bar that I could customize with my own lights but sold it before I could. The Liberty light bar costs around $500 as well so it really doesn't compare with the one made in china that you listed.
Old May 18, 2011 | 01:57 PM
all you need is two gutter mounts and a piece or metal as a cross bar. go!
