Discovery-no spark
Old Aug 21, 2021 | 08:51 AM
Jjcopen's Avatar
Default Discovery-no spark
I have a 2002 Land Robert Discovery that won’t start. No spark to plugs. Changed the crankshaft position sensor and it has new coils, plugs, and wires. When I try to start I get both transmission lights flashing “M” and “S”. No check engine light. Was running fine then one day wouldn’t start. Any ideas?
Old Aug 22, 2021 | 07:58 AM
Jjcopen's Avatar
Default Background info
Here is some background info. Car was having a hard time starting and I suspected the fuel pump (several times my Gas gauge failed to register anything in the tank on a full tank of gas). I replaced the fuel pump and it started on first crank for 2 days. Then nothing. Checked and have no spark at plugs. Beginning to think it wasn’t an issue with fuel pump after all, but maybe another issue. Replaced crank position sensor and still nothing.
Old Aug 22, 2021 | 10:21 AM
mollusc's Avatar
Have you checked the inertia switch? Scanned for immobiliser codes? Camshaft sensor? There are a large number of threads on this forum about dealing with no-spark situations.
Old Aug 23, 2021 | 06:31 PM
The Deputy's Avatar
Check all of your mega fuses in engine compartment fuse box and fuses in drivers compartment fuse box and ignition relay in drivers compartment fuse box.
Old Aug 24, 2021 | 07:08 AM
Jjcopen's Avatar
I checked all the fuses. Scanning it today. I didn’t realize it also had a cam position sensor. Thanks Everyone I’ll keep checking
russellk
Jul 6, 2016 08:27 PM
john baumgarth
Jan 31, 2011 07:44 AM
derek.saylor
Jan 30, 2011 12:50 AM
Boutins
Sep 5, 2010 06:59 PM
glmtd
Jan 8, 2010 11:51 PM
