distributor vac advance used needed!
Old May 25, 2010 | 06:04 PM
kman3786's Avatar
Default distributor vac advance used needed!
So the original distributor is on the car, vac advance is broken totally off......what should i do?!
the arm to the advance is bent, perhaps its supposed to be?
Old May 25, 2010 | 09:22 PM
tornado_735's Avatar
Bump!
Old May 25, 2010 | 09:26 PM
You will need to replace it.
I do not know if you can replace just the advance or not.
There are some good aftermarket distributors out there for alot cheaper than a OEM one.
ALAKDisco
Feb 17, 2012 08:38 AM
BUXTONIONS
Oct 6, 2009 06:43 AM
tweakrover
Jun 10, 2009 04:50 PM
benflynn
Dec 26, 2007 12:55 AM
mach1al
Jun 20, 2005 08:23 PM
