Dive in or cut my losses and get out?
Old May 18, 2020 | 03:36 PM
  #91
Richard Gallant's Avatar
Hmm you should not be able to hear a drip on the inside externally, there are lots of places you could have a small leak and never see it. Dark oil after a rebuild is very possible, depending on how dirty your engine was. But if that image is the colour of your oil you have a problem, that yellow brown colour is a sign of be coolant contamination.
But but takes a lot of water to get that colour.
Old May 18, 2020 | 06:36 PM
  #92
Just wanted to add if you did not get that valley pan gasket set right you will get water in the oil. Those water passages at the ends of the block could leak, and the water will run into the valley and then into the sump. You will to pull the top end, but not teh heads. Before that use a product like the one below :
The only way to find out for sure is to get a fluorescent dye kit
Amazon Amazon
LandBeard
Dec 11, 2016 08:09 PM
radjxf
Aug 30, 2015 01:03 PM
llcookej
Jun 22, 2013 09:26 PM
ehill03
Feb 13, 2011 09:33 PM
pilsner
Jan 17, 2010 09:46 AM
