DIY D2 TerraFirma 2" Suspension Install Video by Rovers North
True Dusty, they are generally a problem. In the video we switch to the Terrafirma model - TERRAFIRMA HD SECR RINGS FOR FRT TOWERS, TF502, RNA502 - Rovers North - Classic Land Rover Parts
Zack what to you think about coil spring compressor tool? I dont have a lift nor a extra hand to help me with the lift install so Ill be doing it by myself when I get home. Dont like the idea of disconnecting the drivshaft and other components as done in video. I have access to a simple tool that grips onto coil spings then you rotate a lever and it compresses the spring thus making it easier to work with and remove/install. I used this method when I removed the lift from my former D1 and it worked well. Any reason why I should NOT use this method for the install of the new lift on my D2?
coil spring compressor is great if you don't have a lift or multiple jacks. unbolt the bottom of the shock, unbolt the shock tower, remover the shock tower and shock as one unit. Install the spring compressor, compress spring, lift it out, no need to remove brakes only the tire. Compress the new spring, put it in place, un-compress it, install shock tower with new shock, tighten bottom of the shock, tighten tower and you done.
make sure you have a coil spring compressor and not a MacPherson strut spring compressor
I just installed this kit on my Disco. The bottom spring mounting plates and the top spring isolators are included probably because SLS equipped Discos do not have come with those plates installed. When I pulled out my stock suspension I noticed that my Disco (a non SLS equipped truck) already had those plates installed. But I did switch em out for the new ones. Keep in mind this kit has two functions: give you a heavy duty 2" life and is a conversion kit for SLS equipped trucks.
