DIY Vacuum Leak Detector
Old Jan 4, 2013 | 12:27 AM
willrok13's Avatar
Default DIY Vacuum Leak Detector
Hey guys, just wanted to show you something I threw together to locate a vacuum leak. I used a spray bottle I picked up in a set from Sam's Club but anything that fits the MAF can be used. With a little garden hose connected to an inner tube pump/vacuum you're good to go. Depending on which side of the pump you plug into, you can pull a vacuum or pressurize the system. It only took a few pumps and I found where one of the factory hose clamps upstream of the Idle air valve was leaking. Just thought I should throw this out there in case someone else wants to try it.
WaltNYC
Jul 27, 2015 02:24 PM
rudy996
Jan 25, 2012 05:27 PM
Spencerfitch
Sep 17, 2010 09:51 PM
krazzz
Dec 1, 2009 10:21 AM
mr_boondoggle
Jan 19, 2009 02:15 PM
