diy wind fairng
Old Feb 7, 2013 | 09:49 AM
jhill15's Avatar
Default diy wind fairng
Hey all, for awhile now i've been wanting a wind fairing for my roof basket. I also didn't want to pay $80. for one. So with a little searching on the internet and the little bit of knowledge that i have... well maybe a pinch of knowledge, I constructed my own with parts i found from lowes for around $20.
this is what i used to make it: some of the items in the picture i already had and some of them i eliminated.
[2] 50" x 8 1/2" sheets of acrylic- found in scrap section $5.00
[2] small u bolts $1.36 each
[2] large u bolts $1.89 each
[1] can of black spray paint $3.96
[1] small bottle of gorilla glue $5.00
Here are the steps:
1. sand all sides of the acrylic sheets so that the glue and paint has something to grab onto.
2. glue the inside of acrylic sheets together and let set over night.
3. make a template and cut the acrylic sheet with a jigsaw (use a small metal blade, and expect the acrylic to melt a little, plus go slow or the acrylic sheet will crack and possibly break)
4. Paint the fairing, sand with fine grit sand paper and paint again...repeat this step until your are happy with the out come.
5. use the large and small u bolts to attach to your cage or basket.
I am still doing small tweaks to it, and it doesn't look exact to the $80 one but it does what its supposed to and im very happy with it.
Attached Thumbnails diy wind fairng-690xt_sized_618x408.jpg   diy wind fairng-20130128_144847.jpg   diy wind fairng-20130206_091446.jpg   diy wind fairng-20130206_142259.jpg   diy wind fairng-20130206_142409.jpg
Old Feb 7, 2013 | 10:00 AM
Lookin' good, only thing missing is the Camel sticker....
Old Feb 7, 2013 | 10:20 AM
jeffh's Avatar
WOW.. you just made a brick out of your roof. Seriously, a fairing should have a nice gentle slope to it. it should sit lower on your roof line attempting to keep air flow from going UNDER the roof rack. It does not matter if it covers the entire front of the rack. You can have a inch or 2 of exposed rack on the top. You should try to re-configure so that the plexi if not touching the roof should be as close to it as possible. The last one I made I put a neoprene strip on the bottom so it would not scratch the roof paint. The idea is to deflect the air up and over not under, and from the pics it appears that the plexi is closer to straight up and down. Other than that it looks great.
Old Feb 7, 2013 | 10:45 AM
greenharoguy's Avatar
X2. A wall is going to be a lot harder to pull through the air then a couple of bars, and a wall is exactly what you made. Bring it down a bit and angle it the sam angle as the the windscreen. That will work much much better.
Old Feb 7, 2013 | 12:31 PM
jhill15's Avatar
Awesome, thanks guys. I will lower it and slope it. Hopefully then it will work like a champ
Old Feb 7, 2013 | 01:38 PM
jhill15's Avatar
OK I adjusted the u bolts and now it has a very nice slop it still doesn't touch the roof of the truck but I think it is better.
Savannah, I found a discovery decade sticker pretty sweet looking. It will go nice on the lower right corner of the fairing, along with the camel trophy sticker.
Thanks guys for the feedback
Old Feb 7, 2013 | 02:10 PM
Pics?
Old Feb 7, 2013 | 03:07 PM
jhill15's Avatar
here are some more pics
Attached Thumbnails diy wind fairng-3.jpg   diy wind fairng-2.jpg   diy wind fairng-1.jpg
Old Feb 7, 2013 | 04:36 PM
BrandonS's Avatar
The wind fairing on the roof rack I made is made out of Plexiglass as well. Instead of thebubolts though I used trim adhesive, its like a super double sided tape, along the bars. Just another option if you didn't want clamps visible. Where it comes arond the sides i used a heat gun to soften it, when it cools it will mostly take that shape. Has held up so far.
Your rack looks nice with it.
Old Feb 7, 2013 | 06:01 PM
jhill15's Avatar
Thanks Brandon, do you have any pics of yours, I would like to see how it looks. I didn't think about using trim adhesive but I bet it looks nicer then those clamps.
