Do all D1 have ABS?
Old 12-12-2009 | 09:01 PM
tibyABv6's Avatar
Default Do all D1 have ABS?
I was under impression that they do...
I have 98 Discovery and it seems that it has no ABS - front wheels lock up on snow and there is no light on my cluster.
I am away for a weeks so cant diagnose it, but my fiance is scared driving it... can blown fuse cause ABS light not to function and brakes not to work properly?
Old 12-12-2009 | 11:52 PM
tornado_735's Avatar
You have no ABS, but as long as you have no light that reads "Brake" then your regular brakes are fine.
Old 12-13-2009 | 12:53 AM
tibyABv6's Avatar
http://www.internetautoguide.com/car...022/index.html
shows it as standard ... mine is LSE model ...i wonder if previous owned took out light bulb as a way to hide the problem...or changed speedo - a bit run down for 79k
Old 12-13-2009 | 01:09 AM
Classklown90's Avatar
i have a 96 and have abs, it started going bad(pulsing in brake) so i pulled the fuse and it was fixed but now the light is constantly on
Old 12-13-2009 | 01:37 AM
tibyABv6's Avatar
So your ABS would kick in for no reason when braking - so you pulled the fuse ... now brakes work normal but no ABS function ....maybe that what happened with mine, but they went one step further and removed ABS light from cluster.
-- Metal shavings on the sensor will set it off causing it to engage ABS when it not suppose to (just one of the causes)
I think i will spend my Christmas brake under the car.
Old 12-13-2009 | 02:19 AM
yes exactly, brakes work perfect, idk what exactly was casuing the abs to malfunction just know that it was and pulling the fuse "solved" it
Old 12-13-2009 | 07:09 AM
antichrist's Avatar
The ABS design in the D1 is really poor as the most common failure mode I've seen reported is almost no brakes on dry pavement. A number of people have run stop signs or lights (including me) when it failed. A well designed system would fail so you have no ABS, not so you have no brakes.
People disabling the ABS on D1's is pretty common, for the above reason.
Old 12-13-2009 | 12:26 PM
SDinDS's Avatar
Could be an easy fix. I pulled the code on mine and found out it was a "brake pedal position switch" Replaced it and ABS has been working fine for over a year now.
Eric
Old 12-13-2009 | 02:56 PM
antichrist's Avatar
Sure, you can fix them, but that doesn't change the fact that they commonly fail in a way that you have little to no brakes.
Old 02-12-2011 | 03:58 PM
ryanmerc's Avatar
7th Gear
Eric
what model disco did you replace the brake pedal position switch? this is different from the brake light switch right? is the same switch that the cruise control uses?
Alan Phillips
11-19-2018 03:27 PM
polargirl0000
08-08-2010 11:45 AM
yuenie
01-13-2010 05:37 PM
Quick Reply: Do all D1 have ABS?
