Do harmonic balancers fail like this? Video.
Old May 23, 2023 | 06:14 AM
ahab's Avatar
Yeah, a few hundred bucks for a chunk of metal stings a little but it's great you caught it before anything bad happened. I doubt it would have bent your crank but eventually something is going to cede to the out of round rotation. Am i seeing one ring of rubber and a couple machined grooves or is there more rubber in there?
Old May 23, 2023 | 12:20 PM
Harvlr's Avatar
I may be having the same issue on my P38. Fortunately I have a (hopefully good) spare pulley.
My question, to replace the front crank seal, Rave says (at least from my memory) to remove the timing cover. I don’t understand why i would need to remove it. Can someone confirm (or deny) that I don’t need to remove the cover?
Old May 23, 2023 | 01:03 PM
ahab's Avatar
AFAIK you do not to remove the cover. It can be a b*tch to get the old seal out, and getting the new one in squarely is a little more challenging with the cover on so it's certainly easier on the bench, but I can't remember a reason the cover would absolutely have to come off.
Old May 23, 2023 | 01:44 PM
Harvlr's Avatar
Thanks Ahab. Timing cover R&R isn’t a small job so I’m hoping I’ll get away without removing it. I just ordered a new seal.
Old May 23, 2023 | 05:21 PM
Tony Luna's Avatar
Originally Posted by Harvlr
With the old one removed can you see what failed?
Not really.
New one is smooth.
Old May 23, 2023 | 05:22 PM
Tony Luna's Avatar
Just one ring of rubber.
Old May 23, 2023 | 05:25 PM
Tony Luna's Avatar
I just installed a new seal with the cover on. Took the fan and lower shroud off. Plenty of room to work and make sure the seal is fully seated/square to the cover
Old May 23, 2023 | 07:27 PM
Harvlr's Avatar
Thanks Tony.
Old May 30, 2023 | 05:14 PM
Harvlr's Avatar
Well I got my new seal today and replaced the front crank pulley. No trouble at all removing and installing a new seal with the timing cover on, but I still have my vibration. I was hoping that the pulley would fix it.
Old May 30, 2023 | 05:31 PM
Harvlr's Avatar
Actually I think the vibration is less, but it’s not as smooth as the Disco. Maybe it’s fine enough (?)
RyanLR3
Jun 15, 2021 06:56 AM
Nic900
Jan 1, 2020 08:02 PM
originalpy
May 5, 2019 05:23 AM
Jeff Blake
May 24, 2017 03:05 PM
DiscoIIBrandon
Feb 7, 2011 08:29 PM
