Do I need to change oil after white shephered?
#21
#23
The rear main might have been an oil pan leak after all. There are a couple od screws deeply burried in the back part of the oil pump next to the bell housing, where some oil was seeping. I just wanted to make sure they were tight and the leaking one was so loose that I could turn it without much force and needed at least 2 turns. And this was not the only loose screw. Most of the rear screws were some what loose and I tightened all of them. Oil filter housing is coming Monday, will drain oil when I install the new filter housing.
collin Barrows
08-28-2011 07:13 AM
Chrisinhouston
11-24-2009 08:49 PM
