Does the pump and hold method still work?
I recenrlty got one of those eBay CD service manual and so far I'm pretty pleased with the info that's on the CD. I couldn't open the on-line RAVE CD properly so I went this route. The first order of the repairis to replace theRR brake caliper tubing, which I got got a new one from AB. Upon looking in the service manual,I was surprise to see what little info the manual gave for bleeding the brakes.Even though the info was correct, I guess I was expecting some elaberate multi-step procedure for bleeding the brakes.
My only question, should I be concern about bleeding the ABS unit or once all four corners are bleed the ABS unit will also be bleed?
Still the best in my book. Start with the RR then go LR, RF,LF. I think if you hold the pedal to the floor the ABS pump will cycle, but I haven't done this myself...
Cheers
Cheers
ORIGINAL: okdiscoguy
Cheers
Cheers
meltdowndave
Dec 17, 2009 09:42 PM
