Does the pump and hold method still work?
Old Mar 18, 2008 | 08:09 PM
CandiMan's Avatar
Default Does the pump and hold method still work?
I recenrlty got one of those eBay CD service manual and so far I'm pretty pleased with the info that's on the CD. I couldn't open the on-line RAVE CD properly so I went this route. The first order of the repairis to replace theRR brake caliper tubing, which I got got a new one from AB. Upon looking in the service manual,I was surprise to see what little info the manual gave for bleeding the brakes.Even though the info was correct, I guess I was expecting some elaberate multi-step procedure for bleeding the brakes.
My only question, should I be concern about bleeding the ABS unit or once all four corners are bleed the ABS unit will also be bleed?
Old Mar 18, 2008 | 09:39 PM
okdiscoguy's Avatar
Default RE: Does the pump and hold method still work?
Still the best in my book. Start with the RR then go LR, RF,LF. I think if you hold the pedal to the floor the ABS pump will cycle, but I haven't done this myself...
Cheers
Old Mar 18, 2008 | 10:18 PM
CandiMan's Avatar
ORIGINAL: okdiscoguy
Cheers
That's what I need to know.With the ignition off,the ADS mudulator unit shouldn't cycle. I guess I need to keep it simple and not expect any specialprocedure K.I.S.S.
earlyrover
Apr 8, 2013 02:04 PM
meltdowndave
Dec 17, 2009 09:42 PM
discodefender
Jan 31, 2009 12:04 PM
Disco2Guy
Jan 31, 2008 04:27 PM
Darover
Dec 8, 2007 12:15 PM
