doing coolant swap. gotta ?
Old Mar 7, 2010 | 07:45 PM
sloppyjoe's Avatar
Default doing coolant swap. gotta ?
doing my coolant and t-stat this week finally.
question is this.
i have a gal of dexcool concentrate and 2 gallons of green 50/50 mix.
dexcool is in the rig now. whats the best way to do a total swap of the dex to green? i dont have a hose near my garage but have a shop sink with water jugs.
do i need to block drain and where are they located? or do i drain the radiator from the bottom hose, change the t-stat. replace the hoses, then refill with water and run and drain again. then replace with green?
i did a search but there are a zillion threads with coolant in the subject line.
btw the discovery has got to have the most plumbing under the hood i have ever seen for water haha.
Old Mar 7, 2010 | 09:18 PM
Well the best way is to drain it, fill with water, turn on the heater, idle until up to temp, let cool for 15 min or so, drain, repeat until nothing but clean water comes out.
After the final drain I always let it sit for several hours to let whatever wants to drip out drip out.
Then put it all back together and refill, bleed the system and then check the level every morning for the next 2-3 mornings after driving it.
Old Mar 10, 2010 | 02:09 PM
yloDiscoII's Avatar
Does one need to use distilled water for the "flush" or will regular ole' hose water be ok? I used hose water in my DI a while back but the cooling system was the trucks ultimate demise (not saying there was any link to using tap water).
Old Mar 10, 2010 | 02:30 PM
hilltoppersx's Avatar
flush with hose water. but when you put coolant that isnt premixed in you need distilled.
Old Mar 10, 2010 | 03:18 PM
yloDiscoII's Avatar
Thanks Ed!
Old Mar 10, 2010 | 03:45 PM
jkid's Avatar
There is a block drain on either side of the engine right next to the engine mounts. They look hard to get at but with the right wrenches and adapters they come out easy enough. I would pull them.
Old Mar 10, 2010 | 05:49 PM
okdiscoguy's Avatar
Flush with water several times, I did mine 5 times. Then open the block drains on the final drain. That will get the hose water out more. Then fill with the pre-mix. You will still have a bunch of hose water in the block if you don't
Old Mar 10, 2010 | 06:41 PM
Jason_B's Avatar
I never could find those damn block plugs!
Old Mar 11, 2010 | 12:17 AM
sloppyjoe's Avatar
done and done.
while it was draining i painted my 2 front wheels black
Old Mar 11, 2010 | 06:07 AM
Originally Posted by sloppyjoe
done and done.
+1 pics please
